Does all these features work on hestiacp?
hi.
Please, do all these features work on hestiacp? Is there anything that needs to be added for the script to work and install?.
most things are installed by default, all other things can be installed afterwards over apt, if the package is missing.
Thank you for your cooperation.
How can i do apt how to do it please.
apt how
apt how
Hosting Requirements:
  • PHP 8.1 or above
  • MySQL 5.7+ or MariaDB
  • At least 2 GB RAM (4 GB recommended)
  • Apache or Nginx server
  • Composer support (for Laravel)
When you want to use hestia, you should already know how apt is working (basicly it is just "apt install php-xxx or php8.3-xxx for specific versions). Hestia is built for sysadmins, which know how to handle linux servers - should just make their lifes easier).
