Does Hestia DNS Cluster require Apache?
I want to configure a Hestia DNS Cluster.
The following is written:
TIP
If you have just set up your slave, check that the host name resolves and that you have a valid SSL certificate
When installed with the following options,
Configure options
bash hst-install.sh --apache no --phpfpm no --vsftpd no --mysql no --exim no --dovecot no --clamav no --spamassassin no --interactive no
Can I enable SSL certificate without Apache?
Or do I need to install Apache?
yes
no, you can also use nginx only which makes anyway more sense for a dns slave.
