Before installing Hestia on my VPS, I installed the X-UI to have my own V2Ray VPN. It was installed correctly and worked very well. I decided to have a website on my VPS then installed Hestia. Now, X-UI doesn’t work. Even I cannot connect to my server using V2Ray. Why? Firewall? or any other problem?
Hestia is designed to be installed on a blank server. I do not have any idea, if it is compatible with your vpn tool - this out of the scope of hestia.
How can I find the problem? your suggestion.
Yep, it was because of firewall. added rules and the problem solved. Thank you Raphael.
