Domain IP Address Help
My server had a hardware issue this week. I fixed the issue and the server came back up. I have 4 domains I have runnning. The issue is that 2 of the domains are showing local ip addreses and not a public ip address causing the sites to not be accessible. The 2 other sites show my public ip address and work fine.
Is it not working when you edit your web domain and assign the public IP?
I have changed it to the public up but it does not save it. It keeps the local address.
The command v-list-sys-ips shows the ips?
What happens if you try to change the ip from command line?
v-change-web-domain-ip YourUser YourDomain ThePublicIP yes
Thank you so much I will try that tonight.
