Domain name conversion does not work
I am setting up one of my home computers for service as Nextcloud. I have installed:
Ubuntu-22.04.4-desktop-amd64
Hestia Control Panel v1.8.12
uborkapodkluch.ru is the domain on which the HestiaCP was installed
oblako.uborkapodkluch.ru is the domain for the Cloud (Nextcloud)
DNS from the Internet seems to work
The rest of the server daemons, on the other hand, aren’t doing so well
How can I fix it?
It works for uborkapodkluch.ru but oblarko.uborkapodkluch.ru doesn’t have an A record assigned.
$ dig uborkapodkluch.ru +noall +ans
uborkapodkluch.ru.      2839    IN      A       5.35.50.118
$ dig oblarko.uborkapodkluch.ru +noall +ans
Also, your router must support Hairpin NAT if you want to access the domain using the public ip inside the private network. Otherwise, edit the file hosts in your client computers to associate uborkapodkluch.ru. and oblarko.uborkapodkluch.ru. to the internal ip of your server.
One more thing, if you plan to use https to connect to your web services, now you have port 443 redirected to a Hikvision portal.
This is where I entered A record and rebooted the server. But A record still doesn’t appear, where else do I need to fix it?
On the control panel of your dns provider that seems your domain registrar:
$ whois uborkapodkluch.ru | grep registrar
registrar:     RU-CENTER-RU
$ dig uborkapodkluch.ru ns +noall +ans
uborkapodkluch.ru.      3600    IN      NS      ns3-l2.nic.ru.
uborkapodkluch.ru.      3600    IN      NS      ns8-cloud.nic.ru.
uborkapodkluch.ru.      3600    IN      NS      ns4-l2.nic.ru.
uborkapodkluch.ru.      3600    IN      NS      ns4-cloud.nic.ru.
uborkapodkluch.ru.      3600    IN      NS      ns8-l2.nic.ru.
Thank you so much! Now it’s clearer where to look for answers
