Ok, so I have a fairly fresh Hestia install. Also, Im not a sysadmin per se, but have been running websites for 20yrs.
I have the NS servers setup and working with one domain on the server which is working perfectly. Everything is set correctly with the registrar and pointing the host name to the IP of the VPS.
I have other domains that I will be moving, but want to get the files setup and the site tested before pointing the domains. So I have a “FloaterDomain.com” that I use to temporarily point to the document root while setting is up and moving databases etc. But I am unable to do that, for the last 2 weeks I’ve been pulling my hair out trying to get this to work.
Everytime I try to point FloaterDomain.com to the Root Document of NewDomain.com, it keeps telling me “Error: DNS record for floaterdomain.com doesn’t exist”. But is does and is also pointed to the NS server on my VPS as it should be.
The DNS records are setup just like the domain that is working.
Can I not do that? If so, then that’s an issue for me. Any tips? Hoping this is something simple I missed. Do I have to rebuild the domain each time?
Also, before the previous bad update, I had the floaterdomain.com pointed to a NewDomain.com Doc root, but then it would go to the one working domain every time.
