I’m trying to do a rsync with 2 servers. I have the pub/key stuff setup, but whenever I try and connect I get:
[email protected]:~# ssh -p 22122 [email protected] false
This service allows sftp connections only.
I’m not sure what else to try? I’ve done server-to-server private/public keys before, but this one just doesn’t seem to want to work
Andy
eris
#2
Did you enable SSH to the admin user via command line? If so it will be reset everytime a updates run
Login via WebUI and change the admin user → Advanced options → SSH and set it to bash
Ahhh that was it ! Not sure why I didn’t think to check that! Thanks
system
closed
#4
