I have added a NodeBB forum to my Hestia server, following the guide in this thread, and using port 3000.
I started the application with its corresponding ./nodebb start and the forum is working with http.
Two issues:
When trying to activate the Let’s Encrypt certificate I get the following error, either via the web or with the v-add-letsencrypt-domain command:
Error: Let's Encrypt validation status 400 (domain). Details: 403: "IP: Invalid response from http://domain/.well-known/acme-challenge/-I have seen this guide on the NodeBB website and have tried to add
location /.well-known/acme-challenge/ {
try_files $uri =404;
to the nodejs3000.stpl and nodejs3000.tpl templates in the /usr/local/hestia/data/templates/web/nginx/ directory and tried to restart the application with v-rebuid-user, but I still get the same error.
Any ideas?
On the previous server where I had the forum I added it as a service to systemctl to keep it always active.
Is this the best option with Hestia or is it better to do it another way?
Thanks in advance.
