Dovecot stops alone
Good morning!
I have dovecot with the default hestiacp configuration with debian 12
Lately the dovecot service stops by itself and I have looked at the logs and apparently it does not indicate the error.
Any idea to prevent this from happening?
Hi @servtelecom
It should show something.
Check again:
systemctl status dovecot --no-pager -l
journalctl -u dovecot --no-pager -l
grep -i dovecot /var/log/syslog
tail /var/log/exim4/paniclog
Also check disk and memory:
df -h
free -m
I don’t see any errors, just this in case it could be the cause:
doveconf: Warning: NOTE: You can get a new clean config file with: doveconf -Pn > dovecot-new.conf
I copied the entire dovecot directory from another installation that works correctly, let’s see if it doesn’t fail again. For the moment, the previous error is no longer mentioned in the log if I restart the dovecot service
I’ll let a few days go by to see if it doesn’t fail!
What I don’t know is if there is any parameter in Dovecot that can increase RAM and CPU consumption in case the problem is that it is too low and that is why it stops. There are several domains and users that consult this server.
I have added the following
service imap {
vsz_limit = 512M
process_limit = 1024
Let’s see if that improves
I did not find the reason why it stops anyway, I have created a script to detect if it is stopped, turn it back on and do it every 5 minutes
thanks
Did these help?
vsz_limit = 512M
In my case the service also stopped. It continues the same, with the script at least it starts it again
How many CPU cores and RAM amount do you have on your server?
Is swap full?
CPU = 6 and RAM = 15GB
