Downgrade to MariaDB 10.4
Hello and good morning to all.
I have a server with Hestia 1.5.13 and I need --for compatibility reasons, to downgrade to MariaDB v.10.4.
The question is: Can I do the downgrade without creating compatibility problems with Hestia 1.5.13?
I look forward to your comments and suggestions.
Thanks,
Yes
backup all databases…
apt remove mariadb-client mariadb-common mariadb-server
apt purge mariadb-client mariadb-common mariadb-server
Modify /etc/apt/sources.list.d/mariadb.list
apt install mariadb-client mariadb-common mariadb-server
Run:
If you need phpmyadmin / roundcube make sure to add the database / users again
OK, thanks @Eris !!
it’s not working to remove old software.
