Hello, playing with a new Drupal 8 install, where I’m planning to migrate an older Drupal 7 site.
Installing any new module or theme, I’m getting in a problem with an error message involving /core/authorize.php/core/authorize.php?
Looking around, it seems a problem with the nginx configuration (so, the Drupal 8 template):
Blockquote This is an nginx configuration issue and discussed intensely on this page Yet curiously no solid solution could be offered. Some guy on an other page proposed a solution. I applied that proposed solution and can confirm that in works!
To apply proposed solution go to your nginx configuration file under
/etc/nginx/sites-available/ directory on Ubuntu and add
Following the instructions found on https://forum.vestacp.com/viewtopic.php?f=10&t=9687&p=34470#p34470
I cloned drupal8.tpl and drupal8.stpl to new modified templates in the folder /usr/local/hestia/data/templates/web/nginx/php-fpm called drupal8_mod.tpl and drupal8_mod.stpl
Now the template looks like this (and it works, for those having the same problem… it will simply pop in the template selection).
Will these changes be destroyed by next upgrade?
