During Remote Backup Did file store in local Machine first?
Hello Forum,
Can anyone please tell me that if i set a remote backup location using FTP/SFTP, then when the backup is generated/created that time is it directly created on that remote location or the backup file first create in local machine then goes to remote location.
I want to know this because my mail server has not that enough space to make backup in local machine but i have another remote machine where i put my backup.
Please help.
Chris.
It is created locally first and then copied over to remoteloction
Thanks for reply Sir,
Is there any way to change this, means backup directly generate in remote location only. i have storage shortage in local machine sir.
Update:
I found a solution to tackle the storage shortage problem in my local machine.
I mount my NFS drive in my server pc as /nfs/backup
then i change the default backup folder to “/nfs/backup” by taking help of official documentation “Backup & Restore | Hestia Control Panel”
now my backup is only generated and store in my shared nfs drive directory, and my storage shortage problem is solved.
thanks hestia for help and for documentation.
Chris.
