I created a nginx template for my Yii2 application, but the generated config for the domain gives me an empty $proxy_extensions
TEMPLATE:
location ~* ^.+\.(%proxy_extensions%)$ {
expires max;
GENERATED CONFIG:
location ~* ^.+\.()$ {
expires max;
Have anyone have some tips to fix it? Or knows why this happens?
FULL TEMPLATE:
root@hestiacp:/etc/nginx/conf.d/domains# cat /usr/local/hestia/data/templates/web/nginx/php-fpm/yii2.tpl
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
# https://hestiacp.com/docs/server-administration/web-templates.html #
server {
listen %ip%:%web_port%;
root %docroot%;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
deny all;
return 404;
# deny accessing php files for the /assets directory
location ~ ^/assets/.*\.php$ {
deny all;
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location / {
try_files $uri $uri/ /index.php$is_args$args;
expires max;
location ~ [^/]\.php(/|$) {
try_files $uri =404;
fastcgi_index index.php;
fastcgi_pass %backend_lsnr%;
location /error/ {
location /vstats/ {
alias %home%/%user%/web/%domain%/stats/;
