Enable HSTS for Hestia admin panel
Sorry if this has been answered elsewhere, I didn’t find it by search.
Is there an official way to enable HSTS for the control panel? i.e. on port 8083?
Cheers
There isn’t one. You could manually modify the server block in /usr/local/hestia/nginx/conf/nginx.conf to add it, but your changes will be overwritten during the next update.
Also, the CLI has an option to add it:
Add Domains HSTS
Getting it added via: hestiacp/bin/v-add-web-domain-ssl-hsts at d4b387a4f03056df2bbee4ebcb52fa50ab949d09 · hestiacp/hestiacp · GitHub
That won’t add HSTS to the control panel on port 8083.
yeah that’s not ideal then - particularly with automatic updates enabled, do you know if it is likely to be added as a toggle in the future? or if it’s possible that the upstream package would be updated to optionally include custom snippets if they exist to avoid the wipeout issue.
Sorry, I don’t know whether there are plans to add it, but you could use a workaround by creating a post install script that Hestia executes on every update, allowing you to add the HSTS conf.
mkdir -p /etc/hestiacp/hooks
touch /etc/hestiacp/hooks/post_install.sh
chmod +x /etc/hestiacp/hooks/post_install.sh
cat > /etc/hestiacp/hooks/post_install.sh << 'EOF'
#!/usr/bin/env bash
HESTIA="/usr/local/hestia"
NGINX_CONF="$HESTIA/nginx/conf/nginx.conf"
NGINX_BIN="$HESTIA/nginx/sbin/hestia-nginx"
NGINX_SERVICE="hestia.service"
if [[ ! -f "$NGINX_CONF" ]]; then
    echo "ERROR: $NGINX_CONF not found"
    exit 1
fi
if [[ ! -x "$NGINX_BIN" ]]; then
    echo "ERROR: $NGINX_BIN not found or not executable"
    exit 1
fi
if grep -q "Strict-Transport-Security" "$NGINX_CONF"; then
    exit 0
fi
if ! grep -q "ssl_certificate_key" "$NGINX_CONF"; then
    echo "ERROR: 'ssl_certificate_key' not found in $NGINX_CONF, cannot insert HSTS header"
    exit 1
fi
if ! sed -i.bak '/ssl_certificate_key/a\\n\t\t# HSTS\n\t\tadd_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;' "$NGINX_CONF"; then
    echo "ERROR: sed failed, restoring backup"
    mv "$NGINX_CONF.bak" "$NGINX_CONF"
    exit 1
fi
if ! "$NGINX_BIN" -t &>/dev/null; then
    echo "ERROR: nginx syntax check failed, restoring backup"
    exit 1
fi
if ! systemctl restart "$NGINX_SERVICE"; then
    echo "ERROR: Failed to restart $NGINX_SERVICE"
    exit 1
fi
EOF
The above commands will create the script to add the HSTS header. Once done, you can execute the script manually to test it.
grep -A3 ssl_certificate_key /usr/local/hestia/nginx/conf/nginx.conf
Thanks Man, that’s just the ticket!
