Team,
i found this PHP module mod_evasive and i want know if is possible install it on hestia or if it will cause problems?.
source: https://phoenixnap.com/kb/apache-mod-evasive
maybe Hestia can be include it on futures version.
Regards,
Team,
Regards,
Never used the module, but basicly: Give it a try, if it works with your os and its version, it basicly should also work with hestia :).
mod_evasive should work just fine, however keep in mind, that nginx as reverse proxy in front might take a lot of requests first and not even pass them onto apache, if they are aiming at more static file types…
