Hi
Can you please tell me how to enable the mod_rewrite.c module? I’m just sure it doesn’t work.
What do you see when you run the following command?
sudo a2query -m | grep rewrite
The conclusion is:
root@server:~# a2query -m | grep rewrite
rewrite (enabled by site administrator)
Does this mean that the module is only available to the administrator?
no, it means that its already enabled - which is or should be the default.
Ok, thank you
