Am having issues installing Hestia, have tried several times with different instance on oracle cloud but always get " Enable SFTP jail…
Error: can’t enable sftp jail". Please anyone with the solution to this?
What happens when you run
v-add-sys-sftp-jail
Hi, I have the same problem, “can’t enable sftp jail”, when I install Hestia CP, I use → bash hst-install.sh and with other installation options and I can’t install it, what can I do?.
Thanks for the help.
Приветствую! Ктонибудь может подсказать решение данной проблемы?
