Enable some disable function for one vhost
Hello, I need certain PHP functions (exec() and shell_exec()) for a single virtual host. How can I do this properly? I tried using an FPM template, but despite phpinfo, the logs say the functions are not enabled.
Regards
You cannot enable functions if they are globally disabled. If you enable them in the php-fpm template, they will appear as enabled, but they still won’t work.
You must do the opposite. Remove those functions from the disable_functions directive in /etc/php/X.Y/fpm/php.ini, restart the php-fpm service and then create a template for the other sites that adds the disabled functions using:
php_admin_value[disable_functions] = here,the,functions
Once done, assign that new template to your sites and rebuild them.
