Enforce STARTTLS for incoming SMTP connection
i want to enforce STARTTLS for incoming emails via SMTP. Means, client must need to issue STARTTLS command before issuing MAIL FROM command. How can i achieve that ? please someone guide me. thanks
So far i tried to add ACL in exim4 config file but it didn’t work,
acl_check_mail:
	deny    condition     = ${if eq{$sender_helo_name}{}}
			message       = HELO required before MAIL
	drop    !authenticated = *
			message       =  Helo name contains an IP address (HELO was $sender_helo_name) and not is valid
			condition     = ${if match{$sender_helo_name}{\N((\d{1,3}[.-]\d{1,3}[.-]\d{1,3}[.-]\d{1,3})|([0-9a-f]{8})|([0-9A-F]{8}))\N}{yes}{no}}
			condition     = ${if match {${lookup dnsdb{>: defer_never,ptr=$sender_host_address}}\}{$sender_helo_name}{no}{yes}}
			delay         = 45s
			condition     = ${if isip{$sender_helo_name}}
			message       = Access denied - Invalid HELO name (See RFC2821 4.1.3)
			condition    = ${if eq{[$interface_address]}{$sender_helo_name}}
			message       = $interface_address is _my_ address
	accept    hosts = : +relay_from_hosts
	accept    authenticated = *
	accept    senders = :
	accept    !hosts = : +relay_from_hosts
			!sender_domains = +local_domains
	deny    message = Must issue a STARTTLS command first.
