I have changed the phpmyadmin alias through hestiacp panel on my debian server and since then I have error 500 on phpmyadmin link. I have checked all the logs and there are no errors at all. I tried to switch back but still error 500.
I’m wondering if it’s related to hestiacp port change, since I’m using port 9000 for hestia and once I had issues with php-fpm and hestia using same port. However, that has been solved and since then I had no problem anymore, since today. Is there a file I miss ?
Nevermind guys, I fixed it, I found the issue and I changed the port to another one so there will be no conflict anymore in the future. Thank you @eris
Yeah, I had issues before, but fixed manually. However, this time I couldn’t find where the issue was. I used 9000 since vesta and I didn’t want to replace the port, but too many problems everytime I have to do something or install a new php version, because I have to set config manually. So, I changed the port and done.
I have the same issue, after changing alias in php.inc , all my domain are done with 500 internal error , when I login to my dashboard and restart Apache and all php configs site start working for a while and problem comes again , I have read through the comments but did not understand the solution anyone here to help me fix this.
