BryceB
January 7, 2021, 7:27pm
#1
I am using a fresh install of ubuntu 20.04.
I just ran the installation script as instructed on the main page. When everything is done, it asks to reboot, and I let it.
After the reboot, I try to visit the control panel, and only get an error. If i try the machine’s IP address, I get a nginx 502 Bad Gateway error. If I try the domain name, I get an apache error 500.
An example line from the nginx error log says:
2021/01/07 12:09:24 [error] 1392#1392: *146 connect() failed (111: Connection refused) while connecting to upstream, client: IP_of_a_computer_on_LAN, server: mydomain, request: “GET / HTTP/1.1”, upstream: “IP_of_the_server:8080/”, host: “mydomain”
Any thoughts?
ScIT
January 7, 2021, 7:58pm
#2
Hi @BryceB
Check the hestia related error log in $HESTIA/log, it will give you more informations. Usualy, it should work out of the box .
BryceB
January 7, 2021, 8:35pm
#3
The $HESTIA/log/error.log reads:
2021-01-07 11:47:30 v-list-user 'admin' [Error 3]
2021-01-07 11:47:34 v-list-user '' [Error 3]
No idea what that could mean.
BryceB
January 7, 2021, 9:09pm
#5
The nginx error log is basically a bunch ol errors that look just like the one I put in the original post.
ScIT
January 7, 2021, 9:11pm
#6
Hmm, can you copy and paste them? They should be different.
Whats the output of systemctl status hestia?
BryceB
January 7, 2021, 9:46pm
#7
I tried to replace everything, but I’m still getting the “New users can only put 2 urls in a post” thing for this forum.
here’s a pastebin of my “systemctl status hestia” results, the contents of my /var/log/nginx/error.log and my /var/log/apache2/error.log
eris
January 7, 2021, 10:11pm
#8
For our info:
https://hostname.com:8083 is working fine?
If not try: /var/log/hestia/nginx-error.log
Also what was your install string
