Hi everyone,
There a problem when i try to add a domain with ñ in DNS, after that the page looks like:
Hi everyone,
Check /var/log/hestia/nginx-error.log
Logs:
2024/04/20 07:34:41 [error] 4065489#0: *5038 FastCGI sent in stderr: "PHP message: PHP Warning: Undefined array key "v_dnssec" in /usr/local/hestia/web/edit/dns/index.php on line 200; PHP message: PHP Warning: Undefined array key "v_dnssec" in /usr/local/hestia/web/edit/dns/index.php on line 213" while reading response header from upstream, client: 127.0.0.1, server: _, request: "POST /edit/dns/?domain=asdasdasdasd.com&token=asdasdasdasd HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "asdasd.com:2083", referrer: "https://asdasdasdasd.com:2083/edit/dns/?domain=asdasdasdasd.com&token=asdasdasdasd"
2024/04/20 07:35:12 [error] 4065489#0: *5038 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#0 /usr/local/hestia/web/list/dns/index.php(14): ksort()
#1 {main}
thrown in /usr/local/hestia/web/list/dns/index.php on line 14" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /list/dns/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "asdasd.com:2083", referrer: "https://asdasd.com:2083/add/dns/"
2024/04/20 07:35:14 [error] 4065489#0: *5038 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
2024/04/20 07:35:26 [error] 4065489#0: *5038 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
thrown in /usr/local/hestia/web/list/dns/index.php on line 14" while reading response header from upstream, client: 127.0.0.1, server: _, request: "GET /list/dns/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "asdasd.com:2083", referrer: "https://asdasd.com:2083/list/web/"
2024/04/20 07:36:44 [error] 4065489#0: *5059 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
2024/04/20 08:01:28 [error] 4065489#0: *5070 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
2024/04/20 08:06:36 [error] 4065489#0: *5074 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
2024/04/20 18:43:03 [error] 4065489#0: *5117 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
2024/04/20 18:44:40 [error] 4065489#0: *5125 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
2024/04/20 19:28:52 [error] 4065489#0: *5137 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ksort(): Argument #1 ($array) must be of type array, null given in /usr/local/hestia/web/list/dns/index.php:14
Stack trace:
#1 {main}
(END)
I have to delete the domain dns with the command v-delete-domains [user] and refresh the page for work, maybe is a problem with domains with ñ and punycode
The only solution is run command:
v-delete-dns-domains [USER] to solve this problem and adding the domain in punycode format.
