Error establishing a database connection!
Hello, guys, after full disk on all websites on hestia “Error establishing a database connection” now i’ve deleted some files and there some space but what can I do now?
Can’t connect to MySQL localhost
ERROR 2002 (HY000): Can’t connect to local server through socket ‘/run/mysqld/mysqld.sock’ (111)
I received an email with the same problem after upgrade and reboot, but ended in “(2)”:
Can't connect to MySQL localhost
ERROR 2002 (HY000): Can't connect to local server through socket '/run/mysqld/mysqld.sock' (2)
I have no databases created.
HestiaCP 1.8.8 on Debian 11 in Hetzner VPS.
i’ve run command “service mysql restart” it helps
I resolved it by going to hestia cpanel > DB > find the database username related to that website, change database password > go back to databse wp config file, changed password > saved.
Works.
