Updating currently installed packages, please wait…
NOTE: This process may take 10 to 15 minutes to complete, please wait… -
Error: apt-get install failed
root@dattacloud:~#
I’m using ubuntu-bionic-18.04-amd64-server
English only please, not gonna use an auto translator here.
probaly run apt update && apt dist-upgrade before the install.
Sorry. yes, I did that update step and it also gave the same error, is it likely that I have to change the OS?
check the installer log in /root (folder called hst-*). Also maybe consider to use ubuntu 20.04 instead of 18.04.
