Error installing hestia CP
W: GPG error: https://apt.hestiacp.com focal InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY A189E93654F0B0E5
E: The repository ‘https://apt.hestiacp.com focal InRelease’ is not signed.
E: Unable to locate package hestia
E: Unable to locate package hestia-nginx
E: Unable to locate package hestia-php
Error: can’t enable sftp jail
sudo LANG=C gpg --no-default-keyring --keyring /usr/share/keyrings/hestia-keyring.gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys A189E93654F0B0E5
Please DM me with your IP adress (Of the server)
It looks like Cloudflare blocked the request
gpg: keyserver receive failed: No route to host
how can I write to you in DM, I can’t figure it out
Sending an email to [email protected] is also fine
Seems it is a network issue trying to reach keyserver.ubuntu.com.
Check if you can resolve the host, the routes used and whether you are blocking some outgoing connections.
dig keyserver.ubuntu.com
traceroute keyserver.ubuntu.com
iptables -S
well let’s try
;; ANSWER SECTION:
keyserver.ubuntu.com.   502
after traceroute keyserver.ubuntu.com :
 ANSWER SECTION:
keyserver.ubuntu.com.   369
If you don’t show the entire output of the commands I can’t help. Anyway, try to connect directly to the keyserver.
telnet keyserver.ubuntu.com 80
If you can’t connect there is a problem with the firewall or the network.
