hello I tried several servers with Debian 10 and I received the same error, I tried with a ubuntu 18.04 server and it works normally, so the error should only be in Debian can you help me?
Could you provide the installation log, you’ll find this in the path written on your screenshot.
Could you have a look at the thread here: Using mod_php instead of PHP-FPM
In special this post to check, if you’re affected by the same issue: Using mod_php instead of PHP-FPM
I did the default install: - wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh - bash hst-install.sh I did the installation with 2 different providers of linode, vultr and I get the same error when installing
I have had the same issue on debain 9 and 10, also getting the same error on ubuntu 18.4 16.04 and 20.04
There is an bug the Hestia-php package please wait for the fix
The issue has been resolved.
