Since the last update it is no longer possible to install HestaCP on Oracle Cloud servers, when doing so it throws the following error and the command “v-change-sys-ip-helo” does not work.
–hostname should be a valid hostname and not ip address. If so it should work fine.
For the last thing:
Add
if [ “${PATH#/usr/local/hestia/bin}” = “$PATH” ]; then
. /etc/profile.d/hestia.sh
fi
to /root/.bashrc
