Error: Key don't have permission to run v-add-fastcgi-cache
When I try to activate fastcgi cache with API, I have the following error:
Error: Key don’t have permission to run v-add-fastcgi-cache
But it doesn’t seems that I can add this right?
Is there another way?
Thanks in advance!
Hi @Ficar,
Yes, you can add the command to the permissions file you are using. For example, if you assigned to the user the billing permissions, edit the file and add v-add-fastcgi-cache to the list
/usr/local/hestia/data/api/billing
Example:
ROLE='admin'
COMMANDS='v-add-user,v-delete-user,v-suspend-user,v-unsuspend-user,v-change-user-shell,v-list-user,v-list-users,v-make-tmp-file,v-add-domain,v-change-user-package,v-make-tmp-file,v-change-user-password,v-add-fastcgi-cache'
Thank you so much it worked!
Have a very nice day :smiley:
