Error: Let's Encrypt acc registration failed - issue in multi server & multi domain
We are facing the SSL issue after upgrading the recent version 1.9.3. In multiple server & multiple domain while trying to add SSL in a newly hosted domain.
We are using DNS from Cloudflare. No proxy is enabled. We check all the relevant SSL related post almost with the same error title but that doesn’t solve issue.
Any suggestion for the resolution?
The problem is not regarding the issue of a certificate but the registration of a new account in Let’s Encrypt.
First, check whether you can reach Let’s Encrypt API endpoint:
curl -ikLm10 https://acme-v02.api.letsencrypt.org/directory
Second, debug the creation of the new account replacing YourUser by the actual user(the output could be large):
bash -x /usr/local/hestia/bin/v-add-letsencrypt-user YourUser 2>&1 | tee /tmp/lets.debug
Result:
curl: (6) Could not resolve host: acme-v02.api.letsencrypt.org
So what should we do now?
Thanks for your reply.
Updating name server using the command
echo “nameserver 8.8.8.8” | sudo tee /etc/resolv.conf > /dev/null
resolved the issue.
You’re welcome.
If you’re using a public resolver like 8.8.8.8 and also using zen.spamhaus.org as a DNSBL for Exim (which is the default), check out this post.:
I forgot to mention that this file is usually overwritten, and you could lose the changes made directly to the file.
