Error: Let’s Encrypt validation status 400 (dosdimensionescreativas.es). Details: 400:“: Fetching https://www.dosdimensionescreativas.es/.well-known/acme-challenge/4wQVuFoWsTyWV_Bci-53RXuPKxaJuf_qRjUvIPnUuLM: Timeout during connect (likely firewall problem)”
Hello, I received this message and don’t know what to do. Can anyone assist me?
Hi @fdouglas27 ,
Your site is redirecting in a loop; http -> https -> http -> https and so on:
$ curl -IkL www.dosdimensionescreativas.es
HTTP/1.1 301 Moved Permanently
Server: nginx
Date: Thu, 07 Mar 2024 13:18:19 GMT
Content-Type: text/html
Content-Length: 162
Connection: keep-alive
HTTP/2 301
server: nginx
date: Thu, 07 Mar 2024 13:18:20 GMT
content-type: text/html
content-length: 162
Server: nginx
Date: Thu, 07 Mar 2024 13:18:20 GMT
Content-Length: 162
HTTP/2 301
server: nginx
content-length: 162
[and so on]
curl: (47) Maximum (50) redirects followed
So you should fix that redirection loop issue.
root@srv448136:/home/administrator/conf/web/dosdimensionescreativas.es# curl -IkL www.dosdimensionescreativas.es
HTTP/1.1 200 OK
Server: nginx
Date: Thu, 07 Mar 2024 16:25:59 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 2574
Last-Modified: Thu, 07 Mar 2024 16:11:00 GMT
Vary: Accept-Encoding
ETag: “65e9e714-a0e”
Accept-Ranges: bytes
I was able to solve the problem that you found. But I can’t generate a ssl certificate. Same message:
Error: Let’s Encrypt validation status 400 ( dosdimensionescreativas.es ). Details: 403:"195.35.8.88: Invalid response from http://www.dosdimensionescreativas.es/.well-known/acme-challenge/qPwEphnI0VOCbF_TMDgmei9OIvrWfTZZW-JukRYjMZ4 : "\n<html lang=\"en\">\n\t\n\t\t<meta charset=\"utf-8\" />\n\t\t<meta name=\"viewport\" content=\"width=device-width, initial""
I was able to resolve it.
Great.
If you resolved it, would be nice if you share the solution so others with the same issue could fix it too
Hi, how did you manage to solve it? It has happened to me 2 times recently, the first one solved itself, but the second one I haven’t managed to solve it yet.
Thank you
system
Closed
April 14, 2024, 4:16pm
8
