At this point, I should access the server to check it. If you agree, I can send you a PM with the instructions to give me access (though I can’t check it right now, it would be in a few hours).
==[Step 5]==
- status: 400
- url: https://acme-v02.api.letsencrypt.org/acme/chall/1826623107/649809422006/hBHDSQ
- nonce: 3aiLGgPYbiXa-1WAKHScYsjkXyP0unBt23b6sVy6FLNnWbnA4Do
- validation:
- details: Unable to update challenge :: authorization must be pending
- answer: HTTP/2 400
server: nginx
date: Wed, 28 Jan 2026 00:12:52 GMT
content-length: 144
boulder-requester: 1826623107
link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index"
replay-nonce: 3aiLGgPYbiXa-1WAKHScYsjkXyP0unBt23b6sVy6FLNnWbnA4Do
"type": "urn:ietf:params:acme:error:malformed",
"detail": "Unable to update challenge :: authorization must be pending",
"status": 400
==[Debug information Step 5]==
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall/1826623107/649809422006/hBHDSQ",
"status": "invalid",
"validated": "2026-01-28T00:11:37Z",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "2606:4700:3035::6815:a9d: Invalid response from http://hugoasb.com/.well-known/acme-challenge/4hM8PAAgKIgMSj6dbHKhWGet-XG1vLXvnRF9H0zJptU: 404",
"status": 403
"token": "4hM8PAAgKIgMSj6dbHKhWGet-XG1vLXvnRF9H0zJptU",
"validationRecord": [
"url": "http://hugoasb.com/.well-known/acme-challenge/4hM8PAAgKIgMSj6dbHKhWGet-XG1vLXvnRF9H0zJptU",
"hostname": "hugoasb.com",
"port": "80",
"addressesResolved": [
"2606:4700:3035::6815:a9d",
"2606:4700:3031::ac43:838b",
"172.67.131.139",
"104.21.10.157"
"addressUsed": "2606:4700:3035::6815:a9d"
For the record.
Apart from the Nginx issue that we had already solved, the problem that was preventing the certificate from being issued was that a modified proxy template was being used that included this section:
location ^~ /.well-known/acme-challenge/ {
root %docroot%;
default_type text/plain;
try_files $uri =404;
That was preventing Nginx from returning the correct response to Let’s Encrypt. Once the domain template was changed to use the default one, the certificate could be issued successfully.
