Error pages not working for .php extension
If the request is for a .php file that isn’t found I get “File not found.” if it is for any other type of file .html for example it goes to the correct 404 page.
I must have done something wrong in the configuration so any advice would be great.
The website uses my own php system. This is something that has happened since migrating my server from and old centos / cpanel to a unbuntu / hestia setup.
If you show the nginx conf for your domain we could take a look.
I’m using apache as a web server. The error pages are configured through the .htaccess file.
I didn’t think I was using nginx
I’ve certainly not modified the default configuration of nginx.
The web address is: https://betterthanapokeintheeye.co.uk
If I go to https://betterthanapokeintheeye.co.uk/banana.html it goes to the correct 404 page.
If I instead go to https://betterthanapokeintheeye.co.uk/banana.php it says File not found.
I can upload the nginx.conf file if you like. That’s the one in /etc/nginx
No, you should upload the nginx conf files for your domain:
/etc/nginx/conf.d/domains/betterthanapokeintheeye.co.uk.conf
/etc/nginx/conf.d/domains/betterthanapokeintheeye.co.uk.ssl.conf
server {
	listen      45.8.225.231:80;
	server_name betterthanapokeintheeye.co.uk www.betterthanapokeintheeye.co.uk betterthanapokeintheeye.uk www.betterthanapokeintheeye.uk;
	error_log   /var/log/apache2/domains/betterthanapokeintheeye.co.uk.error.log error;
	include /home/betterthan/conf/web/betterthanapokeintheeye.co.uk/nginx.forcessl.conf*;
		deny all;
		return 404;
	location / {
		proxy_pass http://45.8.225.231:8080;
		location ~* ^.+\.(css|htm|html|js|json|xml|apng|avif|bmp|cur|gif|ico|jfif|jpg|jpeg|pjp|pjpeg|png|svg|tif|tiff|webp|aac|caf|flac|m4a|midi|mp3|ogg|opus|wav|3gp|av1|avi|m4v|mkv|mov|mpg|mpeg|mp4|mp4v|webm|otf|ttf|woff|woff2|doc|docx|odf|odp|ods|odt|pdf|ppt|pptx|rtf|txt|xls|xlsx|7z|bz2|gz|rar|tar|tgz|zip|apk|appx|bin|dmg|exe|img|iso|jar|msi|webmanifest)$ {
			try_files  $uri @fallback;
			root       /home/betterthan/web/betterthanapokeintheeye.co.uk/public_html;
			access_log /var/log/apache2/domains/betterthanapokeintheeye.co.uk.log combined;
			access_log /var/log/apache2/domains/betterthanapokeintheeye.co.uk.bytes bytes;
			expires    max;
	location @fallback {
	location /error/ {
		alias /home/betterthan/web/betterthanapokeintheeye.co.uk/document_errors/;
	include /home/betterthan/conf/web/betterthanapokeintheeye.co.uk/nginx.conf_*;
server {
	listen      45.8.225.231:443 ssl;
	ssl_certificate     /home/betterthan/conf/web/betterthanapokeintheeye.co.uk/ssl/betterthanapokeintheeye.co.uk.pem;
	ssl_certificate_key /home/betterthan/conf/web/betterthanapokeintheeye.co.uk/ssl/betterthanapokeintheeye.co.uk.key;
	ssl_stapling        on;
	ssl_stapling_verify on;
	# TLS 1.3 0-RTT anti-replay
	include /home/betterthan/conf/web/betterthanapokeintheeye.co.uk/nginx.hsts.conf*;
		deny all;
		return 404;
	location / {
		proxy_pass https://45.8.225.231:8443;
			expires    max;
	location /error/ {
	proxy_hide_header Upgrade;
	include /home/betterthan/conf/web/betterthanapokeintheeye.co.uk/nginx.ssl.conf_*;
Hi @RincewindOook,
Let’s try this (if it works, we will modify the apache template that is using your site):
Edit /etc/apache2/apache2.conf file and add the directive ProxyErrorOverride On
You will get something like this:
PidFile ${APACHE_PID_FILE}
Timeout 30
KeepAlive Off
MaxKeepAliveRequests 100
KeepAliveTimeout 10
ProxyErrorOverride On    <--- this is the line you need to add
Once modified, restart or reload apache2 and try again.
systemctl restart apache2
Thank you that worked.
Is this to make it permanent? I assume the /etc/apache2/apache2.conf is likely to be overwritten on an update.
Yeah that was just to test whether it works.
You should create a new template for apache (so it won’t be replaced in next update) and edit your web domain to assign that template.
As root:
Note: discworld is just an example, use the template name you prefer.
cd /usr/local/hestia/data/templates/web/apache2/php-fpm/
cp default.tpl discworld.tpl
cp default.stpl discworld.stpl
Now edit both files and add the directive ProxyErrorOverride after ErrorLog
Like this (in both files):
    CustomLog /var/log/%web_system%/domains/%domain%.bytes bytes
    CustomLog /var/log/%web_system%/domains/%domain%.log combined
    ErrorLog /var/log/%web_system%/domains/%domain%.error.log
Once done, edit your web domain and in Apache Template select discworld and Save
Now you can remove the directive previously added to /etc/apache2/apache2.conf and restart apache
Thank you.
