Error: SSL intermediate chain is not valid
Hello. When adding a certificate from Sectigo I get an error - Error: SSL intermediate chain is not valid
How to solve the problem?
Insert the full chain, including the intermediate should solve the issue.
I do that. But I get an error.
Do you want to add it to a webdomain or as hestia panel certificate?
I add via web interface. This is a regular domain (site). Not a certificate for the panel
The panel is: v1.9.0~beta1
Bought a new certificate. When adding a certificate, now there is no error, it just does not install. The certificate checkboxes are reset and nothing works.
Does anyone know how to solve this problem?
I still want to return to this problem. The certificate is not installed through the panel. I had to manually go into the nginx and apache configs to install it. That’s the only way it worked.
And through the panel, the error is - Error: SSL intermediate chain is not valid
In the panel logs - 2025-03-03 22:41:35 v-change-web-domain-sslcert ‘test’ ‘test.com’ ‘/tmp/tmp.Qc7xdjAFQ3’ ‘no’ [Error 3]
What’s the matter, maybe I don’t understand?
I’m inserting SSL correctly
Debug mode:
Error: SSL intermediate chain is not valid | DEBUG BACKTRACE: array ( 0 => array ( ‘file’ => ‘/usr/local/hestia/web/edit/web/index.php’, ‘line’ => 710, ‘function’ => ‘check_return_code’, ‘args’ => array ( 0 => 3, 1 => array ( 0 => ‘Error: SSL intermediate chain is not valid’, ), ), ), )
Very strange. Every other time it gets added somehow
Seems a bug in the way Hestia validates it.
Backup function domain.sh
cp /usr/local/hestia/func/domain.sh /usr/local/hestia/func/domain.sh.backup
Now edit /usr/local/hestia/func/domain.sh and replace this (lines 435 to 438):
                s1=$(openssl x509 -text -in $ssl_dir/$domain.crt 2> /dev/null)
                s1=$(echo "$s1" | grep Issuer | awk -F = '{print $6}' | head -n1)
                s2=$(openssl x509 -text -in $ssl_dir/$domain.ca 2> /dev/null)
                s2=$(echo "$s2" | grep Subject | awk -F = '{print $6}' | head -n1)
by this:
                s1=$(openssl x509 -noout -in $ssl_dir/$domain.crt -issuer 2>/dev/null | cut -d = -f2-)
                s2=$(openssl x509 -noout -in $ssl_dir/$domain.ca -subject 2>/dev/null | cut -d = -f2-)
Save the file and try again.
Yes! It worked! Please make this edit globally in the panel.
Done
Thank you. Now we are waiting for a new version.
Also, if you have access to edit, then fix the error on the site - [Bug] Spelling error · Issue #4884 · hestiacp/hestiacp · GitHub
