Error: Web domain DOMAIN.TLD exist trying to add a SUB.DOMAIN.TLD
Hi everyone,
not sure if this is a “known issue”, I went trough GITHUB and I was not able to find anything similar.
Debian 10 - HST 1.4.1 + Apache + Nginx + MultiPHP
This is the issue I am facing is when i try to add a subdomain, let’s call it SUB.DOMAIN.TLD.
There is another unpriviliged user owning the same DOMAIN.TLD
I never had this issue on previous HESTIA releases.
Steps I am doing :
  1. I point to /add/web/ from hestia as unprivileged user, owner of SUB.DOMAIN.TLD
  2. Insert SUB.DOMANIN.TLD in “domain name” field
  3. Keep “Create DNS zone” and “Enable mail for this domain” unchecked
  4. Press save
  5. Error message : Error: Web domain DOMAIN.TLD exists
The issue here seems that the controller of adding domains in HESTIA is checking for a DOMAIN.TLD match rather then SUB.DOMAIN.TLD
Thank you and sorry if I am duplicating.
We have added in 1.4.0 a few new policies:
One of them is:
https://docs.hestiacp.com/admin_docs/settings.html#what-does-the-policy-enforce-subdomain-ownership-mean
You can disable via the settings
See: [BUG] Any user can create a subdomain for any domain using the HestiaCP DNS server even for other users. · Issue #1622 · hestiacp/hestiacp · GitHub and CVE-2021-27231 - Hestia Control Panel 1.4.0 and below - Subdomain Takeover - Improper Privilege Management - Sick Codes - Security Research, Hardware & Software Hacking, Consulting, Linux, IoT, Cloud, Embedded, Arch, Tweaks & Tips! for the reason behind it.
Perfect, thank you ! :wink:
It doesn’t work to me:
ran v-add-web-domain-allow-users USER DOMAIN
gives
Error: web domain DOMAIN doesn't exist
Any tip?
If you have user1 → domain.com
and user2 → sub.domain.com
Use v-add-web-domain-allow-users user1 domain.com
Ok, thanks for the tip, it works perfectly indeed. Nice job here.
