Error while installing Hestia
While trying to install Hestia, mirror.mephi.ru didn’t answer.
[ * ] NGINX
[ * ] PHP
[ * ] MariaDB
[ * ] Hestia Control Panel
Updating currently installed packages, please wait.../
NOTE: This process may take 10 to 15 minutes to complete, please wait...
E: Failed to fetch http://mirror.mephi.ru/debian/pool/main/p/pixman/libpixman-1-0_0.40.0-1_amd64.deb  Error reading from server - read (104: Connection reset by peer) [IP: 85.143.112.112 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
[ * ] Configuring system settings...
[ * ] Configuring Hestia Control Panel...
cp: cannot stat '/usr/local/hestia/install/deb/sudo/admin': No such file or directory
chmod: cannot access '/etc/sudoers.d/admin': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/hestia': No such file or directory
ln: failed to create symbolic link '/usr/local/hestia/log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/system.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/nginx-error.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/auth.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/backup.log': No such file or directory
chmod: cannot access '/usr/local/hestia/log': No such file or directory
chmod: cannot access '/var/log/hestia/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/packages': No such file or directory
sed: can't read /usr/local/hestia/data/packages/*.pkg: No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/unassigned/index.html': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/skel/document_errors/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/firewall': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/api': No such file or directory
[ * ] Generating default self-signed SSL certificate...
hst-install-debian.sh: line 1236: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
[ * ] Adding SSL certificate to Hestia Control Panel...
sed: -e expression #1, char 3: unexpected `,'
sed: -e expression #1, char 1: unknown command: `,'
cp: cannot stat '/usr/local/hestia/install/deb/ssl/dhparam.pem': No such file or directory
[ * ] Enable SFTP jail...
Error: can't enable sftp jail
Now I can’t install again. Installer says:
Error: Hestia install detected. Unable to continue
I know that Hestia hasn’t got uninstaller. So because of mirror.mephi.ru didn’t answer, all the installation proccess crashed with no way to try again.
Is there a way to reinstall Hestia without reinstalling Debian?
Found solution.
rm -rf /usr/local/hestia
