Hi when I want to install hestiacp with ubuntu 18 using this command:
bash hst-install.sh -a yes -n yes -w no -o no -v no -j no -k no -m yes -g no -x no -z no -c no -t no -i yes -b yes -q no -d no -r 8083 -l en -y yes -force
I got this error:
(*) NGINX
(*) PHP
(*) MariaDB
(*) Hestia Control Panel
Extracting templates from packages: 100%lease wait.../
Now installing Hestia Control Panel and all required dependencies.
NOTE: This process may take 10 to 15 minutes to complete, please wait...
(*) Configuring system settings...
sed: can't read /etc/rssh.conf: No such file or directory
chmod: cannot access '/usr/bin/rssh': No such file or directory
(*) Configuring Hestia Control Panel...
cp: cannot stat '/usr/local/hestia/install/deb/sudo/admin': No such file or directory
chmod: cannot access '/etc/sudoers.d/admin': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/hestia': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/packages': No such file or directory
sed: can't read /usr/local/hestia/data/packages/*.pkg: No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/unassigned/index.html': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/skel/document_errors/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/firewall': No such file or directory
(*) Generating default self-signed SSL certificate...
hst-install-ubuntu.sh: line 1078: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
(*) Adding SSL certificate to Hestia Control Panel...
sed: -e expression #1, char 3: unexpected `,'
sed: -e expression #1, char 1: unknown command: `,'
cp: cannot stat '/usr/local/hestia/install/deb/ssl/dhparam.pem': No such file or directory
(*) Configuring NGINX...
cp: cannot stat '/usr/local/hestia/install/deb/nginx/nginx.conf': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/nginx/status.conf': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/nginx/phpmyadmin.inc': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/nginx/phppgadmin.inc': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/nginx': No such file or directory
sed: can't read /etc/nginx/nginx.conf: No such file or directory
sed: can't read /usr/local/hestia/nginx/conf/nginx.conf: No such file or directory
Failed to start nginx.service: Unit nginx.service not found.
Error: nginx start failed
