I’m using the latest version of HestiaCP with Apache + Nginx - Ubuntu 22
I first tried installing GeoIP, using:
/usr/local/hestia/install/upgrade/manual/install_awstats_geoip.sh
But I get the error when accessing awstats:
Error: Plugin init for plugin ‘geoip’ failed with return code: Error opening /usr/share/GeoIP/GeoIP.dat at (eval 8) line 5008, line 717. (A module required by plugin might be missing).
Setup (‘/etc/awstats/conf’ file, web server or permissions) may be wrong.
Check config file, permissions and AWStats documentation (in ‘docs’ directory).
Back snapshot, and I installed GeoIP2:
/usr/local/hestia/install/upgrade/manual/install_awstats_geoip2.sh
But I get the message:
Error: Plugin load for plugin ‘geoip2_country’ failed with return code: Error: Can’t locate GeoIP2/Database/Reader.pm in @INC (you may need to install the GeoIP2::Database::Reader module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.34.0 /usr/local/share/perl/5.34.0 /usr/lib/x86_64-linux-gnu/perl5/5.34 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl-base /usr/lib/x86_64-linux-gnu/perl/5.34 /usr/share/perl/5.34 /usr/local/lib/site_perl /usr/share/awstats/lib /usr/share/awstats/plugins) at (eval 29) line 1. Error: Need Perl module GeoIP2::Database::Reader
In both installations, I received no error!
What to do?
