Errors phpmyadmin
Hello how to fix its problem
Deprecation Notice in ./libraries/classes/Url.php#221
http_build_query(): Passing null to parameter #2 ($numeric_prefix) of type string is deprecated
Backtrace
./libraries/classes/Url.php#221: http_build_query(
array,
NULL,
string ‘&’,
./libraries/classes/Header.php#231: PhpMyAdmin\Url::getCommonRaw()
./libraries/classes/Header.php#282: PhpMyAdmin\Header->getJsParams()
./libraries/classes/Header.php#214: PhpMyAdmin\Header->getJsParamsCode()
./libraries/classes/Header.php#142: PhpMyAdmin\Header->_addDefaultScripts()
./libraries/classes/Response.php#100: PhpMyAdmin\Header->__construct()
./libraries/classes/Response.php#134: PhpMyAdmin\Response->__construct()
./libraries/common.inc.php#432: PhpMyAdmin\Response::getInstance()
./index.php#27: require_once(./libraries/common.inc.php)
Php version 8.2
Phpmyadmin version 4.9.5deb2
Just ignore it it will be changed by phpmyadmin in the future …
Thank you!
