Hi
I am trying to find out a problem where i get " MTP 451 (Temporary local problem - please try later)" when i try to send email on my server. the logs are as follow and the problem occours when i login to roundcube and try to send email. i have not recived any emails either for the last months.
2024-07-14 05:54:18 H=localhost (webmail.trully.com ) [127.0.0.1] sender verify defer for [email protected] : failed to expand “${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/$domain/aliases}}}}”: NULL
2024-07-14 05:54:18 H=localhost (webmail.trully.com ) [127.0.0.1] F=[email protected] A=dovecot_login:[email protected] temporarily rejected RCPT [email protected] : Could not complete sender verify
2024-07-14 05:54:45 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:55:09 H=o18.em.spotify.com [167.89.58.12] X=TLS1.3:ECDHE_SECP256R1__RSA_PSS_RSAE_SHA256__AES_128_GCM:128 CV=no SNI=mail.trully.com F=[email protected] temporarily rejected RCPT [email protected] : failed to expand “${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/$domain/aliases}}}}”: NULL
2024-07-14 05:55:15 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:55:46 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:56:15 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:56:44 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:57:15 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:57:45 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:58:14 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:58:44 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:59:13 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 05:59:42 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 06:00:16 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
2024-07-14 06:00:40 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
ter.yandex.ru > temporarily rejected RCPT [email protected] : failed to expand “${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/$domain/aliases}}}}”: NULL
2024-07-14 06:02:11 dovecot_login authenticator failed for (User) [80.94.95.242]: 535 Incorrect authentication data ([email protected] )
root@cloud:~#
Hi @razzera ,
ls -la /etc/exim4/domains/
for i in /etc/exim4/domains/*/aliases; do echo "Checking $i:"; ls -l "$i" && cat -A "$i";echo;done
Hi!
root@cloud:~# ls -la /etc/exim4/domains/
total 1
lrwxrwxrwx 1 root root 31 Nov 28 2023 trully.com -> /home/trully/conf/mail/trully.com
root@cloud:~# for i in /etc/exim4/domains/*/aliases; do echo "Checking $i:"; ls -l "$i" && cat -A "$i";echo;done
Checking /etc/exim4/domains/trully.com/aliases:
-rw-rw---- 1 Debian-exim mail 48 May 25 23:10 /etc/exim4/domains/trully.com/aliases
*@trully.com:[email protected] $
[email protected] :$
[email protected] : is not a valid entry in /etc/exim4/domains/trully.com/aliases. Did you modify the file manually?
Show also the output of this command:
cat /usr/local/hestia/data/users/trully/mail/trully.com.conf
You don’t have more domains? estioserver.net is one of your domains?
I’ve checked it and seems that above entry remains when you add the option discard all and then remove it. But exim shouldn’t give that error…(failed to expand).
Execute this to view the versions you are using:
curl -sSL https://7j.gg/hcpver | bash -s --
dpkg -l | grep exim4
sahsanu:
No i did not. However i did upgrade from 20.04 to 22.04 of ubuntu.
root@cloud:~# cat /usr/local/hestia/data/users/trully/mail/trully.com.conf
ACCOUNT='admin' ALIAS='' AUTOREPLY='no' FWD='' FWD_ONLY='' MD5='{BLF-CRYPT}$2y$05$removed' RATE_LIMIT='' QUOTA='unlimited' U_DISK='12' SUSPENDED='no' TIME='20:51:52' DATE='2022-12-20'
ACCOUNT='noreply' ALIAS='' AUTOREPLY='no' FWD='' FWD_ONLY='' MD5='{BLF-CRYPT}$2y$05$removed' RATE_LIMIT='' QUOTA='unlimited' U_DISK='1' SUSPENDED='no' TIME='20:53:34' DATE='2022-12-20'
ACCOUNT='allbox' ALIAS='' AUTOREPLY='no' FWD='' FWD_ONLY='' MD5='{BLF-CRYPT}$2y$05$removed' RATE_LIMIT='' QUOTA='unlimited' U_DISK='80' SUSPENDED='no' TIME='22:20:03' DATE='2022-12-21'
ACCOUNT='ads' ALIAS='' AUTOREPLY='no' FWD='' FWD_ONLY='' MD5='{BLF-CRYPT}$2y$05$removed' RATE_LIMIT='' QUOTA='unlimited' U_DISK='4' SUSPENDED='no' TIME='19:16:49' DATE='2023-01-05'
ACCOUNT='web' ALIAS='' AUTOREPLY='no' FWD='' FWD_ONLY='' MD5='{BLF-CRYPT}$2y$05$removed' RATE_LIMIT='' QUOTA='unlimited' U_DISK='1' SUSPENDED='no' TIME='11:31:32' DATE='2023-01-06'
ACCOUNT='operbot' ALIAS='' AUTOREPLY='no' FWD='' FWD_ONLY='' MD5='{BLF-CRYPT}$2y$05$removed' RATE_LIMIT='' QUOTA='unlimited' U_DISK='1' SUSPENDED='no' TIME='20:55:02' DATE='2024-05-25'
root@cloud:~#
root@cloud:~# curl -sSL https://7j.gg/hcpver | bash -s --
Software Version
OS Ubuntu 22.04.4 LTS
Hestia 1.8.11
Hestia-nginx 1.25.2
Hestia-php 8.2.11
Nginx 1.25.5
Apache2 2.4.59
PHP8.0 8.0.30
PHP7.2 7.2.34
PHP7.1 7.1.33
Awstats 7.8
Exim4 4.95
Dovecot 2.3.16
Spamassassin 3.4.6
Clamav 0.103.11
Roundcube 1.6.5
Vsftpd 3.0.5
Bind9 9.18.18
Mariadb 10.6.18
Fail2ban 0.11.2
root@cloud:~#
root@cloud:~# dpkg -l | grep exim4
ii exim4 4.95-4ubuntu2.5 all metapackage to ease Exim MTA (v4) installation
ii exim4-base 4.95-4ubuntu2.5 amd64 support files for all Exim MTA (v4) packages
ii exim4-config 4.95-4ubuntu2.5 all configuration for the Exim MTA (v4)
ii exim4-daemon-heavy 4.95-4ubuntu2.5 amd64 Exim MTA (v4) daemon with extended features, including exiscan-acl
root@cloud:~#
All looks good.
Maybe the update overwritten exim4 conf files. I would need to check them (I don’t know whether I will have time to do today), also, tell me if you are using Sieve in case I need to recreate the conf file.
Share the urls you will get when using these commands (termbin is a tool like pastebin so you can share the contents of files easily):
cat /etc/exim4/update-exim4.conf.conf | nc termbin.com 9999
cat /etc/exim4/exim4.conf.template | nc termbin.com 9999
Just in case, rebuild your mail domain, restart exim and try again.
v-rebuild-mail-domain trully trully.com
systemctl restart exim4
root@cloud:~# cat /etc/exim4/update-exim4.conf.conf | nc termbin.com 9999
https://termbin.com/l8ft
root@cloud:~#
root@cloud:~# cat /etc/exim4/exim4.conf.template | nc termbin.com 9999
https://termbin.com/elsv
root@cloud:~# v-rebuild-mail-domain trully trully.com
root@cloud:~#
root@cloud:~# systemctl restart exim4
root@cloud:~#
still the same after the last 2
Ok, you will need to replace the exim conf file but I need to know if you use sieve.
Also, show the output of this command, I need to know if srs conf file is there.
ls -la /etc/exim4/
I have never heard of sieve so i guess not? if you mean it for remoting or something i could hand you the login details in a PM? =)
total 148
drwxr-xr-x 4 root root 4096 May 25 16:07 .
drwxr-xr-x 106 root root 12288 May 25 16:10 …
drwxr-xr-x 9 root root 4096 Feb 26 2023 conf.d
-rw-r–r-- 1 root root 32 Feb 26 2023 dnsbl.conf
drwxr-xr-x 2 root root 4096 Jul 14 09:09 domains
-rw-r----- 1 root root 17116 Jul 14 06:41 exim4.conf.template
-rw-r----- 1 root root 80414 Jan 11 2024 exim4.conf.template.dpkg-dist
-rw-r–r-- 1 root root 3 Feb 26 2023 limit.conf
-rw-r----- 1 root Debian-exim 204 Nov 23 2022 passwd.client
-rw-r–r-- 1 root root 87 Jul 13 06:27 smtp_relay.conf
-rw-r–r-- 1 root root 0 Feb 26 2023 spam-blocks.conf
-rw-r–r-- 1 root root 442 Feb 26 2023 system.filter
-rw-r–r-- 1 root root 1050 May 25 16:07 update-exim4.conf.conf
-rw-r–r-- 1 root root 0 Feb 26 2023 white-blocks.conf
Sieve is a mail filter included in Dovecot but if you didn’t know what is I suppose you never installed it.
Ok, let’s try to fix it.
cd /etc/exim4/
echo "$(head /dev/urandom | tr -dc A-Za-z0-9 | head -c16)" > srs.conf
chmod 640 srs.conf
chown root:Debian-exim srs.conf
mv exim4.conf.template exim4.conf.template.backup
curl -sSL https://termbin.com/2yrg -o exim4.conf.template
Once done, show the output of:
systemctl status exim4 --no-pager -l
And if no error, try again.
Edit : The termbin link will expire so here is the conf file:
# Exim configuration file for Hestia Control Panel #
SPAMASSASSIN = yes
SPAM_SCORE = 50
SPAM_REJECT_SCORE = 100
CLAMD = yes
smtp_banner = $smtp_active_hostname
smtp_active_hostname = ${lookup dnsdb{>: defer_never,ptr=$interface_address}{${listextract{1}{$value}}}{$primary_hostname}}
add_environment = <; PATH=/bin:/usr/bin
keep_environment =
disable_ipv6 = true
SRS_SECRET = ${readfile{/etc/exim4/srs.conf}}
smtputf8_advertise_hosts =
domainlist local_domains = dsearch;/etc/exim4/domains/
domainlist relay_to_domains = dsearch;/etc/exim4/domains/
hostlist relay_from_hosts = 127.0.0.1
hostlist whitelist = net-iplsearch;/etc/exim4/white-blocks.conf
hostlist spammers = net-iplsearch;/etc/exim4/spam-blocks.conf
no_local_from_check
untrusted_set_sender = *
acl_smtp_connect = acl_check_spammers
acl_smtp_mail = acl_check_mail
acl_smtp_rcpt = acl_check_rcpt
acl_smtp_data = acl_check_data
acl_smtp_mime = acl_check_mime
.ifdef SPAMASSASSIN
spamd_address = 127.0.0.1 783
.endif
.ifdef CLAMD
av_scanner = clamd: /run/clamav/clamd.ctl
.endif
log_selector = +tls_sni
tls_advertise_hosts = *
# We test that $tls_in_sni is a valid domain, by an arbitrary email address [email protected] .
# Then, we extract the domain with a function that would fail if the email address is invalid.
# If the certificate exists, we will use it, otherwise the default certificate in /etc/ssl will be used.
tls_certificate = \
${if and {\
{ eq {${domain:foo@$tls_in_sni}} {$tls_in_sni}}\
{ exists{/usr/local/hestia/ssl/mail/$tls_in_sni.crt} }\
{/usr/local/hestia/ssl/mail/$tls_in_sni.crt}\
{/usr/local/hestia/ssl/certificate.crt}\
tls_privatekey = \
${if and {\
{ exists{/usr/local/hestia/ssl/mail/$tls_in_sni.key} }\
{/usr/local/hestia/ssl/mail/$tls_in_sni.key}\
{/usr/local/hestia/ssl/certificate.key}\
daemon_smtp_ports = 25 : 465 : 587
tls_on_connect_ports = 465
tls_require_ciphers = PERFORMANCE:-RSA:-VERS-ALL:+VERS-TLS1.2:+VERS-TLS1.3:%SERVER_PRECEDENCE
auth_advertise_hosts = localhost : ${if eq{$tls_in_cipher}{}{}{*}}
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 0s
ignore_bounce_errors_after = 2d
timeout_frozen_after = 7d
DKIM_DOMAIN = ${lc:${domain:$h_from:}}
DKIM_FILE = /etc/exim4/domains/${lookup{${lc:${domain:$h_from:}}}dsearch{/etc/exim4/domains/}}/dkim.pem
DKIM_PRIVATE_KEY = ${if exists{DKIM_FILE}{DKIM_FILE}{0}}
OUTGOING_IP = /etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/ip
SMTP_RELAY_FILE = ${if exists{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/smtp_relay.conf}}
SMTP_RELAY_HOST = ${lookup{host}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PORT = ${lookup{port}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_USER = ${lookup{user}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PASS = ${lookup{pass}lsearch{SMTP_RELAY_FILE}}
# Custom Filter
system_filter = /etc/exim4/system.filter
system_filter_user = Debian-exim
# ACL CONFIGURATION #
# Specifies access control lists for incoming SMTP mail #
acl_not_smtp = acl_not_smtp
begin acl
acl_not_smtp:
deny message = Website of user $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
ratelimit = 200 / 1h / $authenticated_id
warn ratelimit = 100 / 1h / strict / $authenticated_id
log_message = Sender rate [limitlog]: log / account / $authenticated_id / $sender_rate / $sender_rate_period
accept
acl_check_spammers:
accept hosts = +whitelist
drop message = Your host in blacklist on this server.
log_message = Host in blacklist
hosts = +spammers
accept
acl_check_mail:
deny condition = ${if eq{$sender_helo_name}{}}
message = HELO required before MAIL
drop !authenticated = *
message = Helo name contains an IP address (HELO was $sender_helo_name) and not is valid
condition = ${if match{$sender_helo_name}{\N((\d{1,3}[.-]\d{1,3}[.-]\d{1,3}[.-]\d{1,3})|([0-9a-f]{8})|([0-9A-F]{8}))\N}{yes}{no}}
condition = ${if match {${lookup dnsdb{>: defer_never,ptr=$sender_host_address}}\}{$sender_helo_name}{no}{yes}}
delay = 45s
condition = ${if isip{$sender_helo_name}}
message = Access denied - Invalid HELO name (See RFC2821 4.1.3)
condition = ${if eq{[$interface_address]}{$sender_helo_name}}
message = $interface_address is _my_ address
accept
acl_check_rcpt:
accept hosts = :
# Limit per email account for SMTP auhenticated users
deny message = Email account $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
set acl_c_msg_limit = ${if exists{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{${lookup {$authenticated_id} lsearch{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{$value}{${readfile{/etc/exim4/limit.conf}}}}}{${readfile{/etc/exim4/limit.conf}}} }
ratelimit = $acl_c_msg_limit / 1h / strict/ $authenticated_id
warn ratelimit = ${eval:$acl_c_msg_limit / 2} / 1h / strict / $authenticated_id
log_message = Sender rate [limitlog]: log / email / $authenticated_id / $sender_rate / $sender_rate_period
deny message = Restricted characters in address
domains = +local_domains
local_parts = ^[.] : ^.*[@%!/|]
domains = !+local_domains
local_parts = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
require verify = sender
accept hosts = +relay_from_hosts
control = submission
accept authenticated = *
control = submission/domain=
deny message = Rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text
hosts = !+whitelist
dnslists = ${readfile {/etc/exim4/dnsbl.conf}{:}}
require message = relay not permitted
domains = +local_domains : +relay_to_domains
deny message = smtp auth required
sender_domains = +local_domains
!authenticated = *
require verify = recipient
.ifdef CLAMD
warn set acl_m0 = no
warn condition = ${if exists {/etc/exim4/domains/$domain/antivirus}{yes}{no}}
set acl_m0 = yes
.endif
.ifdef SPAMASSASSIN
warn set acl_m1 = no
set acl_m3 = no
warn condition = ${if exists {/etc/exim4/domains/$domain/antispam}{yes}{no}}
set acl_m1 = yes
warn condition = ${if exists {/etc/exim4/domains/$domain/reject_spam}{yes}{no}}
set acl_m3 = yes
.endif
accept
acl_check_data:
.ifdef CLAMD
deny message = Message contains a virus ($malware_name) and has been rejected
malware = */defer_ok
condition = ${if eq{$acl_m0}{yes}{yes}{no}}
.endif
.ifdef SPAMASSASSIN
warn !authenticated = *
hosts = !+relay_from_hosts
condition = ${if < {$message_size}{1024K}}
condition = ${if eq{$acl_m1}{yes}{yes}{no}}
spam = debian-spamd:true/defer_ok
add_header = X-Spam-Score: $spam_score_int
add_header = X-Spam-Bar: $spam_bar
add_header = X-Spam-Report: $spam_report
set acl_m2 = $spam_score_int
warn condition = ${if !eq{$acl_m2}{} {yes}{no}}
condition = ${if >{$acl_m2}{SPAM_SCORE} {yes}{no}}
add_header = X-Spam-Status: Yes
message = SpamAssassin detected spam (from $sender_address to $recipients).
# Deny spam at high score if spam score > SPAM_REJECT_SCORE and delete_spam is enabled
deny message = This message scored $spam_score spam points
condition = ${if eq{$acl_m3}{yes}{yes}{no}}
condition = ${if >{$spam_score_int}{SPAM_REJECT_SCORE}{1}{0}}
.endif
accept
acl_check_mime:
deny message = Blacklisted file extension detected
condition = ${if match {${lc:$mime_filename}}{\N(\.ace|\.ade|\.adp|\.app|\.arj|\.asp|\.aspx|\.asx|\.bas|\.bat|\.cab|\.cer|\.chm|\.cmd|\.cnt|\.com|\.cpl|\.crt|\.csh|\.der|\.diagcab|\.dll|\.efi|\.exe|\.fla|\.fon|\.fxp|\.gadget|\.grp|\.hlp|\.hpj|\.hta|\.htc|\.img|\.inf|\.ins|\.iso|\.isp|\.its|\.jar|\.jnlp|\.js|\.jse|\.ksh|\.lib|\.lnk|\.mad|\.maf|\.mag|\.mam|\.maq|\.mar|\.mas|\.mat|\.mau|\.mav|\.maw|\.mcf|\.mda|\.mdb|\.mde|\.mdt|\.mdw|\.mdz|\.msc|\.msh|\.msh1|\.msh1xml|\.msh2|\.msh2xml|\.mshxml|\.msi|\.msp|\.mst|\.msu|\.ops|\.osd|\.pcd|\.pif|\.pl|\.plg|\.prf|\.prg|\.printerexport|\.ps1|\.ps1xml|\.ps2|\.ps2xml|\.psc1|\.psc2|\.psd1|\.psdm1|\.pst|\.py|\.pyc|\.pyo|\.pyw|\.pyz|\.pyzw|\.reg|\.scf|\.scr|\.sct|\.sfx|\.shb|\.shs|\.swf|\.sys|\.theme|\.tmp|\.ttf|\.url|\.vb|\.vba|\.vbe|\.vbp|\.vbs|\.vhd|\.vhdx|\.vsmacros|\.vsw|\.vxd|\.webpnp|\.website|\.wim|\.ws|\.wsc|\.wsf|\.wsh|\.xbap|\.xll|\.xnk)$\N}{1}{0}}
accept
# AUTHENTICATION CONFIGURATION #
begin authenticators
smtp_relay_login:
driver = plaintext
public_name = LOGIN
hide client_send = : SMTP_RELAY_USER : SMTP_RELAY_PASS
dovecot_plain:
driver = dovecot
public_name = PLAIN
server_socket = /run/dovecot/auth-client
server_set_id = $auth1
dovecot_login:
driver = dovecot
public_name = LOGIN
# ROUTERS CONFIGURATION #
# Specifies how addresses are handled #
begin routers
send_via_unauthenticated_smtp_relay:
driver = manualroute
address_data = SMTP_RELAY_HOST:SMTP_RELAY_PORT
require_files = SMTP_RELAY_FILE
condition = ${if eq{SMTP_RELAY_USER}{}}
transport = remote_smtp
route_list = * ${extract{1}{:}{$address_data}}::${extract{2}{:}{$address_data}}
no_more
no_verify
send_via_smtp_relay:
transport = smtp_relay_smtp
no_more
no_verify
dnslookup:
driver = dnslookup
# if outbound, and forwarding has been done, use an alternate transport
domains = ! +local_domains
transport = ${if eq {$local_part@$domain} \
{$original_local_part@$original_domain} \
{remote_smtp} {remote_forwarded_smtp}}
no_more
userforward:
driver = redirect
check_local_user
file = $home/.forward
require_files = ${local_part}:+${home}/.forward
allow_filter
no_verify
no_expn
check_ancestor
file_transport = address_file
pipe_transport = address_pipe
reply_transport = address_reply
procmail:
driver = accept
check_local_user
require_files = ${local_part}:+${home}/.procmailrc:/usr/bin/procmail
transport = procmail
no_verify
autoreplay:
driver = accept
require_files = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg
condition = ${if exists{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg}{yes}{no}}
retry_use_local_part
transport = userautoreply
unseen
inbound_srs:
driver = redirect
senders = :
# detect inbound bounces which are SRS'd, and decode them
condition = ${if inbound_srs {$local_part} {SRS_SECRET}}
data = $srs_recipient
inbound_srs_failure:
driver = redirect
senders = :
# detect inbound bounces which look SRS'd but are invalid
condition = ${if inbound_srs {$local_part} {}}
allow_fail
data = :fail: Invalid SRS recipient address
aliases:
driver = redirect
headers_add = X-redirected: yes
data = ${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
require_files = /etc/exim4/domains/$domain/aliases
redirect_router = dnslookup
unseen
localuser_fwd_only:
driver = accept
transport = devnull
condition = ${if exists{/etc/exim4/domains/$domain/fwd_only}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/fwd_only}{true}{false}}}}
localuser_spam:
driver = accept
transport = local_spam_delivery
condition = ${if eq {${if match{$h_X-Spam-Status:}{\N^Yes\N}{yes}{no}}} {${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{yes}{no_such_user}}}}
localuser:
driver = accept
transport = local_delivery
condition = ${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{true}{false}}
catchall:
driver = redirect
data = ${extract{1}{:}{${lookup{*@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
file_transport = local_delivery
condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{false}{true}}
terminate_alias:
driver = accept
transport = devnull
condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{true}{false}}
# TRANSPORTS CONFIGURATION #
begin transports
smtp_relay_smtp:
driver = smtp
remote_smtp:
driver = smtp
helo_data = ${lookup dnsdb{>: defer_never,ptr=$sending_ip_address}{${listextract{1}{$value}}}{$primary_hostname}}
dkim_domain = DKIM_DOMAIN
dkim_selector = mail
dkim_private_key = DKIM_PRIVATE_KEY
dkim_canon = relaxed
dkim_strict = 0
hosts_try_fastopen = !*.l.google.com
interface = ${if exists{OUTGOING_IP}{${readfile{OUTGOING_IP}}}}
remote_forwarded_smtp:
driver = smtp
dkim_strict = 0
# modify the envelope from, for mails that we forward
max_rcpt = 1
return_path = ${srs_encode {SRS_SECRET} {$return_path} {$original_domain}}
procmail:
driver = pipe
command = "/usr/bin/procmail -d $local_part"
return_path_add
delivery_date_add
envelope_to_add
user = $local_part
initgroups
return_output
local_delivery:
driver = appendfile
maildir_format
maildir_use_size_file
user = ${extract{2}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}
group = mail
create_directory
directory_mode = 770
mode = 660
use_lockfile = no
delivery_date_add
envelope_to_add
return_path_add
directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
quota = ${extract{6}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}M
quota_warn_threshold = 75%
local_spam_delivery:
driver = appendfile
maildir_format
group = mail
create_directory
mode = 660
use_lockfile = no
delivery_date_add
envelope_to_add
return_path_add
directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}/.Spam"
quota_directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
address_pipe:
driver = pipe
return_output
address_file:
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
address_reply:
driver = autoreply
userautoreply:
driver = autoreply
file = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}.msg
from = "${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}@${lookup{$domain}dsearch{/etc/exim4/domains/}}"
headers = Content-Type: text/plain; charset=utf-8;\nContent-Transfer-Encoding: 8bit
subject = "${if def:h_Subject: {Autoreply: \"${rfc2047:$h_Subject:}\"} {Autoreply Message}}"
to = "${sender_address}"
devnull:
driver = appendfile
file = /dev/null
# RETRY CONFIGURATION #
begin retry
# Address or Domain Error Retries
* * F,2h,15m; G,16h,1h,1.5; F,4d,6h
# REWRITE CONFIGURATION #
begin rewrite
Thank you a lot!
this owrked wonderfully, i cant helpt to thank you enough for this!!
root@cloud:/etc/exim4# systemctl status exim4 --no-pager -l
● exim4.service - LSB: exim Mail Transport Agent
Loaded: loaded (/etc/init.d/exim4; generated)
Active: active (running) since Sun 2024-07-14 11:18:00 CEST; 6s ago
Process: 1713677 ExecStart=/etc/init.d/exim4 start (code=exited, status=0/SUCCESS)
Tasks: 2 (limit: 28748)
Memory: 15.2M
CPU: 427ms
CGroup: /system.slice/exim4.service
├─1713927 /usr/sbin/exim4 -bd -q30m
└─1713954 /usr/sbin/exim4 -bd -q30m
Jul 14 11:17:59 cloud.sptfy.com systemd[1]: Starting LSB: exim Mail Transport Agent…
Jul 14 11:17:59 cloud.sptfy.com exim4[1713677]: * Starting MTA
Jul 14 11:18:00 cloud.sptfy.com exim4[1713677]: …done.
Jul 14 11:18:00 cloud.sptfy.com exim4[1713677]: ALERT: exim paniclog /var/log/exim4/paniclog has non-zero size, mail system possibly broken
Jul 14 11:18:00 cloud.sptfy.com systemd[1]: Started LSB: exim Mail Transport Agent.
I’m glad it worked
Just one more thing:
ls -l /var/log/exim4/paniclog
tail /var/log/exim4/paniclog
Ok, those are older entries, just empty the file and that’s all
:> /var/log/exim4/paniclog
Hey
I found another problem. When emails are sent trough an email Relay now i get
i get “@195134086.t-sender-sib.com ” and not @domain.com
That “issue” is not coming from Hestia/Exim but Brevo. You must configure Brevo to allow that domain.
Login into Brevo -> Senders, Domains and Dedicated IPs -> Domains -> Add your domain and you will need to modify three TXT records for your domain to include the brevo-code, the dkim public key and dmarc (those records should be added to your current dns provider (DreamHost)).
Hi Again!
I have another question regarding this.
everything is working fine but the ability to send mail trough my php website. I have website email SMTP settings set with email and password in the config but no emails aare getting trough like password resets.
I’ll let any other community buddy to answer you because I don’t use php to send mails but:
1.- You should explain how you configured that php app.
2.- You should check the logs, maybe the error is there.
