I am new to HestiaCP and need help setting up. How do I get paid help to setup HestiaCP - nameserver, web, DNS and mail servers?
After installation Exim4 will not come up with the following error. I tried to uninstall and install but no luck.
Jul 01 13:46:51 xxx.com systemd[1]: Starting exim4.service - exim Mail Transport Agent…
Jul 01 13:46:51 xxx.com update-exim4.conf[803198]: 2025-07-01 13:46:51 Exim configuration error in line 50 of /var/lib/exim4/config.autogenerated.tmp:
Jul 01 13:46:51 xxx.com update-exim4.conf[803198]: main option “acl_smtp_mime” unknown
Jul 01 13:46:51 xxx.com update-exim4.conf[803200]: Invalid new configfile /var/lib/exim4/config.autogenerated.tmp, not installing
Jul 01 13:46:51 xxx.com update-exim4.conf[803200]: /var/lib/exim4/config.autogenerated.tmp to /var/lib/exim4/config.autogenerated
Are you sure the acl_smtp_mime
error occurred after the first installation and not after reinstalling Exim?
curl -fsSLm15 https://7j.gg/hcpver | bash -s --
dpkg -l | grep exim4
yes, the error occurred right after installation. we attempted to fix it but there were other problems so we removed to be reinstalled. Here is the requested info:
$ curl -fsSLm15 https://7j.gg/hcpver | bash -s –
Software Version
OS Ubuntu 24.04.2 LTS
Hestia 1.9.3
Hestia-nginx 1.27.4
Hestia-php 8.3.17
FileGator 7.13.0
Nginx 1.27.5
PHP8.4 8.4.8
PHP8.3 8.3.22
PHP8.2 8.2.28
PHP8.1 8.1.32
PHP8.0 8.0.30
PHP7.4 7.4.33
PHP7.3 7.3.33
PHP7.2 7.2.34
PHP7.1 7.1.33
PHP7.0 7.0.33
PHP5.6 5.6.40
Awstats 7.9
Dovecot 2.3.21
Spamassassin 4.0.0
Clamav 1.0.8
Vsftpd 3.0.5
Bind9 9.18.30
PostgreSQL 16.9
phpPgAdmin 7.14.6
Fail2ban 1.0.2
$ dpkg -l | grep exim4
empty because we have removed it and want to reinstall
This script will purge Exim4, reinstall it and configure it to use SpamAssassin and ClamAV.
First, backup /etc/exim4
mkdir -p /root/backup_etc_exim4/
cp -prf /etc/exim4/ /root/backup_etc_exim4/
Now execute the script:
curl -fsSLm15 https://7j.gg/instexim | sudo bash -s --
Once finished, show the output of this command:
systemctl status exim4 --no-pager -l
Just in case, this is the script:
#!/usr/bin/env bash
if [[ $EUID -ne 0 ]]; then
echo "Error: script must be run as root"
exit 2
fi
export PATH=$PATH:/sbin
HESTIA='/usr/local/hestia'
HESTIA_BIN="$HESTIA/bin"
HESTIA_INSTALL_DIR="$HESTIA/install/deb"
HESTIA_COMMON_DIR="$HESTIA/install/common"
version_ge() { test "$(printf '%s\n' "$@" | sort -V | head -n 1)" != "$1" -o -n "$1" -a "$1" = "$2"; }
gen_pass() {
matrix=$1
length=$2
if [ -z "$matrix" ]; then
matrix="A-Za-z0-9"
fi
if [ -z "$length" ]; then
length=16
fi
head /dev/urandom | tr -dc $matrix | head -c$length
check_result() {
if [ $1 -ne 0 ]; then
echo "Error: $2"
exit $1
fi
#Remove and reinstall exim4
exim=yes
spamd=yes
clamd=yes
sieve=no
echo "[ * ] Removing Exim4 packages"
apt purge -q -y "exim4*" &>/dev/null
echo "[ * ] Installing Exim4 packages"
apt install -q -y exim4 exim4-daemon-heavy &>/dev/null
if [ "$exim" = 'yes' ]; then
"$HESTIA_BIN/v-change-sys-config-value" "MAIL_SYSTEM" "exim4"
if [ "$clamd" = 'yes' ]; then
"$HESTIA_BIN/v-change-sys-config-value" "ANTIVIRUS_SYSTEM" "clamav-daemon"
fi
if [ "$spamd" = 'yes' ]; then
"$HESTIA_BIN/v-change-sys-config-value" "ANTISPAM_SYSTEM" "spamassassin"
fi
if [ "$sieve" = 'yes' ]; then
"$HESTIA_BIN/v-change-sys-config-value" "SIEVE_SYSTEM" "yes"
fi
fi
echo "[ * ] Configuring Exim mail server"
gpasswd -a Debian-exim mail >/dev/null 2>&1
exim_version=$(exim4 --version | head -1 | awk '{print $3}' | cut -f -2 -d .)
# if Exim version > 4.9.4 or greater!
if ! version_ge "4.94" "$exim_version"; then
# Ubuntu 22.04 (Jammy) uses Exim 4.95 instead but config works with Exim4.94
cp -f $HESTIA_INSTALL_DIR/exim/exim4.conf.4.95.template /etc/exim4/exim4.conf.template
else
cp -f $HESTIA_INSTALL_DIR/exim/exim4.conf.template /etc/exim4/
fi
cp -f $HESTIA_INSTALL_DIR/exim/dnsbl.conf /etc/exim4/
cp -f $HESTIA_INSTALL_DIR/exim/spam-blocks.conf /etc/exim4/
cp -f $HESTIA_INSTALL_DIR/exim/limit.conf /etc/exim4/
cp -f $HESTIA_INSTALL_DIR/exim/system.filter /etc/exim4/
touch /etc/exim4/white-blocks.conf
sed -i "s/#SPAM/SPAM/g" /etc/exim4/exim4.conf.template
fi
sed -i "s/#CLAMD/CLAMD/g" /etc/exim4/exim4.conf.template
fi
# Generate SRS KEY If not support just created it will get ignored anyway
srs=$(gen_pass)
echo $srs >/etc/exim4/srs.conf
chmod 640 /etc/exim4/srs.conf
chmod 640 /etc/exim4/exim4.conf.template
chown root:Debian-exim /etc/exim4/srs.conf
rm -rf /etc/exim4/domains
mkdir -p /etc/exim4/domains
rm -f /etc/alternatives/mta
ln -s /usr/sbin/exim4 /etc/alternatives/mta
update-rc.d -f sendmail remove >/dev/null 2>&1
update-rc.d -f postfix remove >/dev/null 2>&1
systemctl stop postfix >/dev/null 2>&1
update-rc.d exim4 defaults
systemctl start exim4 >/dev/null
check_result $? "exim4 start failed"
fi
echo "[ * ] Done!"
It works!
This is the output:
$ systemctl status exim4 --no-pager -l
● exim4.service - exim Mail Transport Agent
Loaded: loaded (/usr/lib/systemd/system/exim4.service; enabled; preset: enabled)
Active: active (running) since Thu 2025-07-03 01:13:18 UTC; 1min 7s ago
Docs: man:exim(8)
Documentation for Exim
Main PID: 33969
Tasks: 1 (limit: 9429)
Memory: 14.5M (peak: 25.4M)
CPU: 391ms
CGroup: /system.slice/exim4.service
└─33969 /usr/sbin/exim4 -bdf -q30m
Jul 03 01:13:18 [1]: Starting exim4.service - exim Mail Transport Agent…
Jul 03 01:13:18 systemd[1]: Started exim4.service - exim Mail Transport Agent.
