Exim4 your reverse DNS does not match with your sending domain
First of all let me thank you for your work on hestia which is a fantastic tool for Webmasters with few resources.
When I test mail-tester.com I get the error “Your reverse DNS does not match with your sending domain”.
Helo: vps
rDNS: vps.domain.es (domain changed for security)
I think the problem occurs because at the time of installation of the hestia script I used as hostname “vps”, however, seeing my error I changed it to “vps.domain.es” using the command “/usr/local/hestia/bin/v-change-sys-hostname vps.domain.es”.
It seems that somewhere the old hostname has been saved, I’ve been doing this all morning and I can’t find where I need to change it…
The emails are sent correctly for most providers except for outlook.
Could you help me?
Did you check if your (mail) DNS is correct? https://dnschecker.org
Yes is correct, The problem is that the helo is set as “vps” and not as “vps.domain.es” so it doesn’t work, the only thing I need to figure out is how can I change the helo to point to the domain…
Probably you can set this in your customer profile of your VPS provider. Or ask their customer support to set the rDNS.
I have found the problem. If I go to the file /etc/exim4/exim4.conf.template there is a flag:
helo_data = ${lookup dnsdb{>: defer_never,ptr=$sending_ip_address}{${listextract{1}{$value}}}{$primary_hostname}}
If I replace it with helo_data = $primary_hostname everything seems to be working properly. What exactly does the standard code do?
First one does an dns look up
Probally it says in /etc/hosts
127.0.0.1 vps
Lo acabo de revisar y tengo lo siguiente:
127.0.0.1 vps.domain.es localhost
Puede ser por el localhost?
I only speak English (Or Dutch)
Sorry, I mean that in the file that you specify I have linked 127.0.0.1 vps.domain.es localhost so in principle I see it well.
