OS: Ubuntu 22.04 (x86_64)
HestiaCp Version: v1.8.11
I used below hestiacp installation command on a clean server
wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh
While installation I noticed below error multiple times on console
Use of uninitialized value Sucode_vars{“AVAIL”} in concatenation (.) or string at /us/sbin/needrestart line 931.
After that the script finished and my system restarted. Everything was working fine, looked good until I opened phpmyadmin, opening phpmyadmin gave me below error
Error Existing configuration file (/etc/phpmyadmin/config.inc.php) is not readable
I solved this by running below command as mentioned in forum
chown -R root:www-data /etc/phpmyadmin/
I hope you can fix such issues which occur in fresh installation.
Surya
