Fail2ban does not work
root@mcro07:/var/log# systemctl status fail2ban.service
x fail2ban.service - Fail2Ban Service
Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Fri 2023-11-10 14:46:15 CET; 17min ago
Duration: 150ms
Docs: man:fail2ban(1)
Process: 192 ExecStart=/usr/bin/fail2ban-server -xf start (code=exited, status=255/EXCEPTION)
Main PID: 192 (code=exited, status=255/EXCEPTION)
CPU: 142ms
Nov 10 14:46:15 mcro07 systemd[1]: Started fail2ban.service - Fail2Ban Service.
Nov 10 14:46:15 mcro07 fail2ban-server[192]: 2023-11-10 14:46:15,793 fail2ban.configreader [192]: WARNING ‘allowipv6’ not defined in ‘Definition’. Using default one: ‘auto’
Nov 10 14:46:15 mcro07 fail2ban-server[192]: 2023-11-10 14:46:15,823 fail2ban [192]: ERROR Failed during configuration: Have not found any log file for exim-iptables jail
Nov 10 14:46:15 mcro07 fail2ban-server[192]: 2023-11-10 14:46:15,825 fail2ban [192]: ERROR Async configuration of server failed
Nov 10 14:46:15 mcro07 systemd[1]: fail2ban.service: Main process exited, code=exited, status=255/EXCEPTION
Nov 10 14:46:15 mcro07 systemd[1]: fail2ban.service: Failed with result ‘exit-code’.
Did you install exim?
ls -l /var/log/exim4/mainlog
grep -A4 exim-iptables /etc/fail2ban/jail.local
root@mcro07:/etc/fail2ban# ls -l /var/log/exim4/mainlog
-rw-r----- 1 Debian-exim adm 2886 Nov 10 15:46 /var/log/exim4/mainlog
[exim-iptables]
enabled = true
filter = exim
action = hestia[name=MAIL]
logpath = /var/log/exim4/mainlog
That looks fine.
Just to test, edit /etc/fail2ban/jail.local and replace enabled = true to enabled = false
Save the file and restart fail2ban.
systemctl restart fail2ban
Unfortunately it did not work out
-rw-r----- 1 Debian-exim adm 3856 Nov 10 16:26 /var/log/exim4/mainlog
[exim-iptables]
enabled = false
filter = exim
root@mcro07:/etc/fail2ban# systemctl restart fail2ban.service
root@mcro07:/etc/fail2ban# systemctl status fail2ban.service
Active: failed (Result: exit-code) since Fri 2023-11-10 16:31:41 CET; 7s ago
Duration: 112ms
Process: 18771 ExecStart=/usr/bin/fail2ban-server -xf start (code=exited, status=255/EXCEPTION)
Main PID: 18771 (code=exited, status=255/EXCEPTION)
CPU: 112ms
Nov 10 16:31:41 mcro07.metacortex.at systemd[1]: Started fail2ban.service - Fail2Ban Service.
Nov 10 16:31:41 mcro07.metacortex.at fail2ban-server[18771]: 2023-11-10 16:31:41,425 fail2ban.configreader [18771]: WARNING ‘allowipv6’ not defined in '>
Nov 10 16:31:41 mcro07.metacortex.at fail2ban-server[18771]: 2023-11-10 16:31:41,445 fail2ban [18771]: ERROR Failed during configuration:>
Nov 10 16:31:41 mcro07.metacortex.at fail2ban-server[18771]: 2023-11-10 16:31:41,446 fail2ban [18771]: ERROR Async configuration of serve>
Nov 10 16:31:41 mcro07.metacortex.at systemd[1]: fail2ban.service: Main process exited, code=exited, status=255/EXCEPTION
Nov 10 16:31:41 mcro07.metacortex.at systemd[1]: fail2ban.service: Failed with result ‘exit-code’.
Did you modify in some way /etc/fail2ban/jail.conf and/or /etc/fail2ban/jail.local?
how was error log in roundcube deleted now it works again after i created the log file again
