Fail2ban won't start after running this script
Hey,
I wanted to install FTP after having already installed hestiacp and I found this script: Can I install FTP after the HestiaCP installation? - #4 by sahsanu
The thing is that, it didn’t installed ftp and now fail2ban won’t start :frowning:
Is there a way to resolve that please?
Thanks!
The script gave any error?
dpkg -l | grep -E '^ii.*vsftpd'
systemctl status vsftpd --no-pager -l
systemctl status fail2ban --no-pager -l
cat /etc/fail2ban/jail.local
v-list-sys-config json | grep FTP | sed -E 's/^\s*//'
The script didn’t give any error
dpkg -l | grep -E ‘^ii.*vsftpd’
ii  vsftpd                                 3.0.5-0ubuntu1                               amd64        lightweight, efficient FTP server written for security
● vsftpd.service - vsftpd FTP server
     Loaded: loaded (/lib/systemd/system/vsftpd.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2024-06-07 19:57:05 CEST; 58min ago
    Process: 820 ExecStartPre=/bin/mkdir -p /var/run/vsftpd/empty (code=exited, status=0/SUCCESS)
   Main PID: 828 (vsftpd)
      Tasks: 1 (limit: 4550)
     Memory: 1.9M
        CPU: 94ms
     CGroup: /system.slice/vsftpd.service
             └─828 /usr/sbin/vsftpd /etc/vsftpd.conf
juin 07 19:57:05 cp.mysite.fr systemd[1]: Starting vsftpd FTP server...
juin 07 19:57:05 cp.mysite.fr systemd[1]: Started vsftpd FTP server.
juin 07 20:10:54 cp.mysite.fr vsftpd[15514]: pam_unix(vsftpd:auth): check pass; user unknown
juin 07 20:10:54 cp.mysite.fr vsftpd[15514]: pam_unix(vsftpd:auth): authentication failure; logname= uid=0 euid=0 tty=ftp ruser=anonymous rhost=207.90.244.6
× fail2ban.service - Fail2Ban Service
     Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Fri 2024-06-07 20:34:46 CEST; 21min ago
       Docs: man:fail2ban(1)
    Process: 17462 ExecStart=/usr/bin/fail2ban-server -xf start (code=exited, status=255/EXCEPTION)
   Main PID: 17462 (code=exited, status=255/EXCEPTION)
        CPU: 177ms
juin 07 20:34:46 cp.mysite.fr systemd[1]: Started Fail2Ban Service.
juin 07 20:34:46 cp.mysite.fr fail2ban-server[17462]: 2024-06-07 20:34:46,668 fail2ban                [17462]: ERROR   Failed during configuration: Have not found any log file for selinux-ssh jail
juin 07 20:34:46 cp.mysite.fr fail2ban-server[17462]: 2024-06-07 20:34:46,669 fail2ban                [17462]: ERROR   Async configuration of server failed
juin 07 20:34:46 cp.mysite.fr systemd[1]: fail2ban.service: Main process exited, code=exited, status=255/EXCEPTION
juin 07 20:34:46 cp.mysite.fr systemd[1]: fail2ban.service: Failed with result 'exit-code'.
# WARNING: heavily refactored in 0.9.0 release.  Please review and
#          customize settings for your setup.
# Changes:  in most of the cases you should not modify this
#           file, but provide customizations in jail.local file,
#           or separate .conf files under jail.d/ directory, e.g.:
# HOW TO ACTIVATE JAILS:
# YOU SHOULD NOT MODIFY THIS FILE.
# It will probably be overwritten or improved in a distribution update.
# Provide customizations in a jail.local file or a jail.d/customisation.local.
# For example to change the default bantime for all jails and to enable the
# ssh-iptables jail the following (uncommented) would appear in the .local file.
# See man 5 jail.conf for details.
# [DEFAULT]
# bantime = 1h
# [sshd]
# enabled = true
# See jail.conf(5) man page for more information
# Comments: use '#' for comment lines and ';' (following a space) for inline comments
[INCLUDES]
#before = paths-distro.conf
before = paths-debian.conf
# The DEFAULT allows a global definition of the options. They can be overridden
# in each jail afterwards.
[DEFAULT]
# MISCELLANEOUS OPTIONS
# "bantime.increment" allows to use database for searching of previously banned ip's to increase a
# default ban time using special formula, default it is banTime * 1, 2, 4, 8, 16, 32...
#bantime.increment = true
# "bantime.rndtime" is the max number of seconds using for mixing with random time
# to prevent "clever" botnets calculate exact time IP can be unbanned again:
#bantime.rndtime =
# "bantime.maxtime" is the max number of seconds using the ban time can reach (doesn't grow further)
#bantime.maxtime =
# "bantime.factor" is a coefficient to calculate exponent growing of the formula or common multiplier,
# default value of factor is 1 and with default value of formula, the ban time
# grows by 1, 2, 4, 8, 16 ...
#bantime.factor = 1
# "bantime.formula" used by default to calculate next value of ban time, default value below,
# the same ban time growing will be reached by multipliers 1, 2, 4, 8, 16, 32...
#bantime.formula = ban.Time * (1<<(ban.Count if ban.Count<20 else 20)) * banFactor
# more aggressive example of formula has the same values only for factor "2.0 / 2.885385" :
#bantime.formula = ban.Time * math.exp(float(ban.Count+1)*banFactor)/math.exp(1*banFactor)
# "bantime.multipliers" used to calculate next value of ban time instead of formula, coresponding
# previously ban count and given "bantime.factor" (for multipliers default is 1);
# following example grows ban time by 1, 2, 4, 8, 16 ... and if last ban count greater as multipliers count,
# always used last multiplier (64 in example), for factor '1' and original ban time 600 - 10.6 hours
#bantime.multipliers = 1 2 4 8 16 32 64
# following example can be used for small initial ban time (bantime=60) - it grows more aggressive at begin,
# for bantime=60 the multipliers are minutes and equal: 1 min, 5 min, 30 min, 1 hour, 5 hour, 12 hour, 1 day, 2 day
#bantime.multipliers = 1 5 30 60 300 720 1440 2880
# "bantime.overalljails" (if true) specifies the search of IP in the database will be executed
# cross over all jails, if true (dafault), only current jail of the ban IP will be searched
#bantime.overalljails = true
# "ignoreself" specifies whether the local resp. own IP addresses should be ignored
# (default is true). Fail2ban will not ban a host which matches such addresses.
#ignoreself = true
# "ignoreip" can be a list of IP addresses, CIDR masks or DNS hosts. Fail2ban
# will not ban a host which matches an address in this list. Several addresses
# can be defined using space (and/or comma) separator.
ignoreip = 127.0.0.1/8 ::1 192.178.5.0/27 34.100.182.96/28 34.101.50.144/28 34.118.254.0/28 34.118.66.0/28 34.126.178.96/28 34.146.150.144/28 34.147.110.144/28 34.151.74.144/28 34.152.50.64/28 34.154.114.144/28 34.155.98.32/28 34.165.18.176/28 34.175.160.64/28 34.176.130.16/28 34.22.85.0/27 34.64.82.64/28 34.65.242.112/28 34.80.50.80/28 34.88.194.0/28 34.89.10.80/28 34.89.198.80/28 34.96.162.48/28 35.247.243.240/28 66.249.64.0/27 66.249.64.128/27 66.249.64.160/27 66.249.64.192/27 66.249.64.224/27 66.249.64.32/27 66.249.64.64/27 66.249.64.96/27 66.249.65.0/27 66.249.65.160/27 66.249.65.192/27 66.249.65.224/27 66.249.65.32/27 66.249.65.64/27 66.249.65.96/27 66.249.66.0/27 66.249.66.128/27 66.249.66.160/27 66.249.66.192/27 66.249.66.32/27 66.249.66.64/27 66.249.66.96/27 66.249.68.0/27 66.249.68.32/27 66.249.68.64/27 66.249.69.0/27 66.249.69.128/27 66.249.69.160/27 66.249.69.192/27 66.249.69.224/27 66.249.69.32/27 66.249.69.64/27 66.249.69.96/27 66.249.70.0/27 66.249.70.128/27 66.249.70.160/27 66.249.70.192/27 66.249.70.224/27 66.249.70.32/27 66.249.70.64/27 66.249.70.96/27 66.249.71.0/27 66.249.71.128/27 66.249.71.160/27 66.249.71.192/27 66.249.71.224/27 66.249.71.32/27 66.249.71.64/27 66.249.71.96/27 66.249.72.0/27 66.249.72.128/27 66.249.72.160/27 66.249.72.192/27 66.249.72.224/27 66.249.72.32/27 66.249.72.64/27 66.249.72.96/27 66.249.73.0/27 66.249.73.128/27 66.249.73.160/27 66.249.73.192/27 66.249.73.224/27 66.249.73.32/27 66.249.73.64/27 66.249.73.96/27 66.249.74.0/27 66.249.74.128/27 66.249.74.32/27 66.249.74.64/27 66.249.74.96/27 66.249.75.0/27 66.249.75.128/27 66.249.75.160/27 66.249.75.192/27 66.249.75.224/27 66.249.75.32/27 66.249.75.64/27 66.249.75.96/27 66.249.76.0/27 66.249.76.128/27 66.249.76.160/27 66.249.76.192/27 66.249.76.224/27 66.249.76.32/27 66.249.76.64/27 66.249.76.96/27 66.249.77.0/27 66.249.77.128/27 66.249.77.160/27 66.249.77.192/27 66.249.77.224/27 66.249.77.32/27 66.249.77.64/27 66.249.77.96/27 66.249.78.0/27 66.249.78.32/27 66.249.79.0/27 66.249.79.128/27 66.249.79.160/27 66.249.79.192/27 66.249.79.224/27 66.249.79.32/27 66.249.79.64/27 66.249.79.96/27
# External command that will take an tagged arguments to ignore, e.g. <ip>,
# and return true if the IP is to be ignored. False otherwise.
# ignorecommand = /path/to/command <ip>
ignorecommand =
# "bantime" is the number of seconds that a host is banned.
bantime  = 10m
# A host is banned if it has generated "maxretry" during the last "findtime"
# seconds.
findtime  = 10m
# "maxretry" is the number of failures before a host get banned.
maxretry = 5
# "maxmatches" is the number of matches stored in ticket (resolvable via tag <matches> in actions).
maxmatches = %(maxretry)s
# "backend" specifies the backend used to get files modification.
# Available options are "pyinotify", "gamin", "polling", "systemd" and "auto".
# This option can be overridden in each jail as well.
# pyinotify: requires pyinotify (a file alteration monitor) to be installed.
#              If pyinotify is not installed, Fail2ban will use auto.
# gamin:     requires Gamin (a file alteration monitor) to be installed.
#              If Gamin is not installed, Fail2ban will use auto.
# polling:   uses a polling algorithm which does not require external libraries.
# systemd:   uses systemd python library to access the systemd journal.
#              Specifying "logpath" is not valid for this backend.
#              See "journalmatch" in the jails associated filter config
# auto:      will try to use the following backends, in order:
#              pyinotify, gamin, polling.
# Note: if systemd backend is chosen as the default but you enable a jail
#       for which logs are present only in its own log files, specify some other
#       backend for that jail (e.g. polling) and provide empty value for
#       journalmatch. See https://github.com/fail2ban/fail2ban/issues/959#issuecomment-74901200
backend = auto
# "usedns" specifies if jails should trust hostnames in logs,
#   warn when DNS lookups are performed, or ignore all hostnames in logs
# yes:   if a hostname is encountered, a DNS lookup will be performed.
# warn:  if a hostname is encountered, a DNS lookup will be performed,
#        but it will be logged as a warning.
# no:    if a hostname is encountered, will not be used for banning,
#        but it will be logged as info.
# raw:   use raw value (no hostname), allow use it for no-host filters/actions (example user)
usedns = warn
# "logencoding" specifies the encoding of the log files handled by the jail
#   This is used to decode the lines from the log file.
#   Typical examples:  "ascii", "utf-8"
#   auto:   will use the system locale setting
logencoding = auto
# "enabled" enables the jails.
#  By default all jails are disabled, and it should stay this way.
#  Enable only relevant to your setup jails in your .local or jail.d/*.conf
# true:  jail will be enabled and log files will get monitored for changes
# true: jail is not enabled
enabled = true
# "mode" defines the mode of the filter (see corresponding filter implementation for more info).
mode = normal
# "filter" defines the filter to use by the jail.
#  By default jails have names matching their filter name
filter = %(__name__)s[mode=%(mode)s]
# ACTIONS
# Some options used for actions
# Destination email address used solely for the interpolations in
# jail.{conf,local,d/*} configuration files.
destemail = root@localhost
# Sender email address used solely for some actions
sender = root@<fq-hostname>
# E-mail action. Since 0.8.1 Fail2Ban uses sendmail MTA for the
# mailing. Change mta configuration parameter to mail if you want to
# revert to conventional 'mail'.
mta = sendmail
# Default protocol
protocol = tcp
# Specify chain where jumps would need to be added in ban-actions expecting parameter chain
chain = <known/chain>
# Ports to be banned
# Usually should be overridden in a particular jail
port = 0:65535
# Format of user-agent https://tools.ietf.org/html/rfc7231#section-5.5.3
fail2ban_agent = Fail2Ban/%(fail2ban_version)s
# Action shortcuts. To be used to define action parameter
# Default banning action (e.g. iptables, iptables-new,
# iptables-multiport, shorewall, etc) It is used to define
# action_* variables. Can be overridden globally or per
# section within jail.local file
banaction = iptables-multiport
banaction_allports = iptables-allports
# The simplest action to take: ban only
action_ = %(banaction)s[port="%(port)s", protocol="%(protocol)s", chain="%(chain)s"]
# ban & send an e-mail with whois report to the destemail.
action_mw = %(action_)s
            %(mta)s-whois[sender="%(sender)s", dest="%(destemail)s", protocol="%(protocol)s", chain="%(chain)s"]
# ban & send an e-mail with whois report and relevant log lines
# to the destemail.
action_mwl = %(action_)s
             %(mta)s-whois-lines[sender="%(sender)s", dest="%(destemail)s", logpath="%(logpath)s", chain="%(chain)s"]
# See the IMPORTANT note in action.d/xarf-login-attack for when to use this action
# ban & send a xarf e-mail to abuse contact of IP address and include relevant log lines
# to the destemail.
action_xarf = %(action_)s
             xarf-login-attack[service=%(__name__)s, sender="%(sender)s", logpath="%(logpath)s", port="%(port)s"]
# ban IP on CloudFlare & send an e-mail with whois report and relevant log lines
# to the destemail.
action_cf_mwl = cloudflare[cfuser="%(cfemail)s", cftoken="%(cfapikey)s"]
# Report block via blocklist.de fail2ban reporting service API
# See the IMPORTANT note in action.d/blocklist_de.conf for when to use this action.
# Specify expected parameters in file action.d/blocklist_de.local or if the interpolation
# `action_blocklist_de` used for the action, set value of `blocklist_de_apikey`
# in your `jail.local` globally (section [DEFAULT]) or per specific jail section (resp. in
# corresponding jail.d/my-jail.local file).
action_blocklist_de  = blocklist_de[email="%(sender)s", service="%(__name__)s", apikey="%(blocklist_de_apikey)s", agent="%(fail2ban_agent)s"]
# Report ban via badips.com, and use as blacklist
# See BadIPsAction docstring in config/action.d/badips.py for
# documentation for this action.
# NOTE: This action relies on banaction being present on start and therefore
# should be last action defined for a jail.
action_badips = badips.py[category="%(__name__)s", banaction="%(banaction)s", agent="%(fail2ban_agent)s"]
# Report ban via badips.com (uses action.d/badips.conf for reporting only)
action_badips_report = badips[category="%(__name__)s", agent="%(fail2ban_agent)s"]
# Report ban via abuseipdb.com.
# See action.d/abuseipdb.conf for usage example and details.
action_abuseipdb = abuseipdb
# Choose default action.  To change, just override value of 'action' with the
# interpolation to the chosen action shortcut (e.g.  action_mw, action_mwl, etc) in jail.local
# globally (section [DEFAULT]) or per specific section
action = %(action_)s
# JAILS
# SSH servers
[sshd]
# To use more aggressive sshd modes set filter parameter "mode" in jail.local:
# normal (default), ddos, extra or aggressive (combines all).
# See "tests/files/logs/sshd" or "filter.d/sshd.conf" for usage example and details.
#mode   = normal
port    = ssh
logpath = %(sshd_log)s
backend = %(sshd_backend)s
[dropbear]
port     = ssh
logpath  = %(dropbear_log)s
backend  = %(dropbear_backend)s
[selinux-ssh]
port     = ssh
logpath  = %(auditd_log)s
# HTTP servers
[apache-auth]
port     = http,https
logpath  = %(apache_error_log)s
[apache-badbots]
# Ban hosts which agent identifies spammer robots crawling the web
# for email addresses. The mail outputs are buffered.
port     = http,https
logpath  = %(apache_access_log)s
bantime  = 48h
maxretry = 1
[apache-noscript]
port     = http,https
[apache-overflows]
port     = http,https
maxretry = 2
[apache-nohome]
port     = http,https
maxretry = 2
[apache-botsearch]
port     = http,https
maxretry = 2
[apache-fakegooglebot]
port     = http,https
maxretry = 1
ignorecommand = %(ignorecommands_dir)s/apache-fakegooglebot <ip>
[apache-modsecurity]
port     = http,https
maxretry = 2
[apache-shellshock]
port    = http,https
maxretry = 1
[openhab-auth]
filter = openhab
banaction = %(banaction_allports)s
logpath = /opt/openhab/logs/request.log
[nginx-http-auth]
port    = http,https
logpath = %(nginx_error_log)s
# To use 'nginx-limit-req' jail you should have `ngx_http_limit_req_module`
# and define `limit_req` and `limit_req_zone` as described in nginx documentation
# http://nginx.org/en/docs/http/ngx_http_limit_req_module.html
# or for example see in 'config/filter.d/nginx-limit-req.conf'
[nginx-limit-req]
port    = http,https
[nginx-botsearch]
port     = http,https
maxretry = 2
# Ban attackers that try to use PHP's URL-fopen() functionality
# through GET/POST variables. - Experimental, with more than a year
# of usage in production environments.
[php-url-fopen]
port    = http,https
logpath = %(nginx_access_log)s
[suhosin]
port    = http,https
logpath = %(suhosin_log)s
[lighttpd-auth]
# Same as above for Apache's mod_auth
# It catches wrong authentifications
port    = http,https
logpath = %(lighttpd_error_log)s
# Webmail and groupware servers
[roundcube-auth]
port     = http,https
logpath  = %(roundcube_errors_log)s
# Use following line in your jail.local if roundcube logs to journal.
#backend = %(syslog_backend)s
[openwebmail]
port     = http,https
logpath  = /var/log/openwebmail.log
[horde]
port     = http,https
logpath  = /var/log/horde/horde.log
[groupoffice]
port     = http,https
logpath  = /home/groupoffice/log/info.log
[sogo-auth]
# Monitor SOGo groupware server
# without proxy this would be:
# port    = 20000
port     = http,https
logpath  = /var/log/sogo/sogo.log
[tine20]
logpath  = /var/log/tine20/tine20.log
port     = http,https
# Web Applications
[drupal-auth]
port     = http,https
logpath  = %(syslog_daemon)s
[guacamole]
port     = http,https
logpath  = /var/log/tomcat*/catalina.out
#logpath  = /var/log/guacamole.log
[monit]
#Ban clients brute-forcing the monit gui login
port = 2812
logpath  = /var/log/monit
           /var/log/monit.log
[webmin-auth]
port    = 10000
logpath = %(syslog_authpriv)s
[froxlor-auth]
port    = http,https
# HTTP Proxy servers
[squid]
port     =  80,443,3128,8080
logpath = /var/log/squid/access.log
[3proxy]
port    = 3128
logpath = /var/log/3proxy.log
# FTP servers
[proftpd]
port     = ftp,ftp-data,ftps,ftps-data
logpath  = %(proftpd_log)s
backend  = %(proftpd_backend)s
[pure-ftpd]
logpath  = %(pureftpd_log)s
backend  = %(pureftpd_backend)s
[gssftpd]
[wuftpd]
logpath  = %(wuftpd_log)s
backend  = %(wuftpd_backend)s
[vsftpd]
# or overwrite it in jails.local to be
# logpath = %(syslog_authpriv)s
# if you want to rely on PAM failed login attempts
# vsftpd's failregex should match both of those formats
logpath  = %(vsftpd_log)s
# Mail servers
# ASSP SMTP Proxy Jail
[assp]
port     = smtp,465,submission
logpath  = /root/path/to/assp/logs/maillog.txt
[courier-smtp]
logpath  = %(syslog_mail)s
[postfix]
# To use another modes set filter parameter "mode" in jail.local:
mode    = more
logpath = %(postfix_log)s
backend = %(postfix_backend)s
[postfix-rbl]
filter   = postfix[mode=rbl]
maxretry = 1
[sendmail-auth]
port    = submission,465,smtp
[sendmail-reject]
# To use more aggressive modes set filter parameter "mode" in jail.local:
# normal (default), extra or aggressive
# See "tests/files/logs/sendmail-reject" or "filter.d/sendmail-reject.conf" for usage example and details.
#mode    = normal
[qmail-rbl]
filter  = qmail
logpath = /service/qmail/log/main/current
# dovecot defaults to logging to the mail syslog facility
# but can be set by syslog_facility in the dovecot configuration.
[dovecot]
port    = pop3,pop3s,imap,imaps,submission,465,sieve
logpath = %(dovecot_log)s
backend = %(dovecot_backend)s
[sieve]
[solid-pop3d]
port    = pop3,pop3s
logpath = %(solidpop3d_log)s
[exim]
# see filter.d/exim.conf for further modes supported from filter:
#mode = normal
logpath = %(exim_main_log)s
[exim-spam]
[kerio]
port    = imap,smtp,imaps,465
logpath = /opt/kerio/mailserver/store/logs/security.log
# Mail servers authenticators: might be used for smtp,ftp,imap servers, so
# all relevant ports get banned
[courier-auth]
port     = smtp,465,submission,imap,imaps,pop3,pop3s
[postfix-sasl]
filter   = postfix[mode=auth]
# You might consider monitoring /var/log/mail.warn instead if you are
# running postfix since it would provide the same log lines at the
# "warn" level but overall at the smaller filesize.
[perdition]
port   = imap,imaps,pop3,pop3s
[squirrelmail]
port = smtp,465,submission,imap,imap2,imaps,pop3,pop3s,http,https,socks
logpath = /var/lib/squirrelmail/prefs/squirrelmail_access_log
[cyrus-imap]
port   = imap,imaps
[uwimap-auth]
port   = imap,imaps
# DNS servers
# !!! WARNING !!!
#   Since UDP is connection-less protocol, spoofing of IP and imitation
#   of illegal actions is way too simple.  Thus enabling of this filter
#   might provide an easy way for implementing a DoS against a chosen
#   victim. See
#    http://nion.modprobe.de/blog/archives/690-fail2ban-+-dns-fail.html
#   Please DO NOT USE this jail unless you know what you are doing.
# IMPORTANT: see filter.d/named-refused for instructions to enable logging
# This jail blocks UDP traffic for DNS requests.
# [named-refused-udp]
# filter   = named-refused
# port     = domain,953
# protocol = udp
# logpath  = /var/log/named/security.log
# This jail blocks TCP traffic for DNS requests.
[named-refused]
port     = domain,953
[nsd]
port     = 53
action_  = %(default/action_)s[name=%(__name__)s-tcp, protocol="tcp"]
           %(default/action_)s[name=%(__name__)s-udp, protocol="udp"]
logpath = /var/log/nsd.log
# Miscellaneous
[asterisk]
port     = 5060,5061
logpath  = /var/log/asterisk/messages
maxretry = 10
[freeswitch]
port     = 5060,5061
logpath  = /var/log/freeswitch.log
maxretry = 10
# enable adminlog; it will log to a file inside znc's directory by default.
[znc-adminlog]
port     = 6667
logpath  = /var/lib/znc/moddata/adminlog/znc.log
# To log wrong MySQL access attempts add to /etc/my.cnf in [mysqld] or
# equivalent section:
# log-warnings = 2
# for syslog (daemon facility)
# [mysqld_safe]
# syslog
# for own logfile
# [mysqld]
# log-error=/var/log/mysqld.log
[mysqld-auth]
port     = 3306
logpath  = %(mysql_log)s
backend  = %(mysql_backend)s
# Log wrong MongoDB auth (for details see filter 'filter.d/mongodb-auth.conf')
[mongodb-auth]
# change port when running with "--shardsvr" or "--configsvr" runtime operation
port     = 27017
logpath  = /var/log/mongodb/mongodb.log
# Jail for more extended banning of persistent abusers
# !!! WARNINGS !!!
# 1. Make sure that your loglevel specified in fail2ban.conf/.local
#    is not at DEBUG level -- which might then cause fail2ban to fall into
#    an infinite loop constantly feeding itself with non-informative lines
# 2. Increase dbpurgeage defined in fail2ban.conf to e.g. 648000 (7.5 days)
#    to maintain entries for failed logins for sufficient amount of time
[recidive]
logpath  = /var/log/fail2ban.log
bantime  = 1w
findtime = 1d
# Generic filter for PAM. Has to be used with action which bans all
# ports such as iptables-allports, shorewall
[pam-generic]
# pam-generic filter can be customized to monitor specific subset of 'tty's
[xinetd-fail]
banaction = iptables-multiport-log
maxretry  = 2
# stunnel - need to set port for this
[stunnel]
logpath = /var/log/stunnel4/stunnel.log
[ejabberd-auth]
port    = 5222
logpath = /var/log/ejabberd/ejabberd.log
[counter-strike]
logpath = /opt/cstrike/logs/L[0-9]*.log
tcpport = 27030,27031,27032,27033,27034,27035,27036,27037,27038,27039
udpport = 1200,27000,27001,27002,27003,27004,27005,27006,27007,27008,27009,27010,27011,27012,27013,27014,27015
action_  = %(default/action_)s[name=%(__name__)s-tcp, port="%(tcpport)s", protocol="tcp"]
           %(default/action_)s[name=%(__name__)s-udp, port="%(udpport)s", protocol="udp"]
[softethervpn]
port     = 500,4500
protocol = udp
logpath  = /usr/local/vpnserver/security_log/*/sec.log
[gitlab]
port    = http,https
logpath = /var/log/gitlab/gitlab-rails/application.log
[grafana]
port    = http,https
logpath = /var/log/grafana/grafana.log
[bitwarden]
port    = http,https
logpath = /home/*/bwdata/logs/identity/Identity/log.txt
[centreon]
port    = http,https
logpath = /var/log/centreon/login.log
# consider low maxretry and a long bantime
# nobody except your own Nagios server should ever probe nrpe
[nagios]
logpath  = %(syslog_daemon)s     ; nrpe.cfg may define a different log_facility
maxretry = 1
[oracleims]
# see "oracleims" filter file for configuration requirement for Oracle IMS v6 and above
logpath = /opt/sun/comms/messaging64/log/mail.log_current
[directadmin]
logpath = /var/log/directadmin/login.log
port = 2222
[portsentry]
logpath  = /var/lib/portsentry/portsentry.history
maxretry = 1
[pass2allow-ftp]
# this pass2allow example allows FTP traffic after successful HTTP authentication
# knocking_url variable must be overridden to some secret value in jail.local
knocking_url = /knocking/
filter       = apache-pass[knocking_url="%(knocking_url)s"]
# access log of the website with HTTP auth
blocktype    = RETURN
returntype   = DROP
action       = %(action_)s[blocktype=%(blocktype)s, returntype=%(returntype)s,
                        actionstart_on_demand=true, actionrepair_on_unban=true]
bantime      = 1h
maxretry     = 1
findtime     = 1
[murmur]
# AKA mumble-server
port     = 64738
logpath  = /var/log/mumble-server/mumble-server.log
[screensharingd]
# For Mac OS Screen Sharing Service (VNC)
logpath  = /var/log/system.log
logencoding = utf-8
[haproxy-http-auth]
# HAProxy by default doesn't log to file you'll need to set it up to forward
# logs to a syslog server which would then write them to disk.
# See "haproxy-http-auth" filter for a brief cautionary note when setting
# maxretry and findtime.
logpath  = /var/log/haproxy.log
[slapd]
port    = ldap,ldaps
logpath = /var/log/slapd.log
[domino-smtp]
port    = smtp,ssmtp
logpath = /home/domino01/data/IBM_TECHNICAL_SUPPORT/console.log
[phpmyadmin-syslog]
port    = http,https
[zoneminder]
# Zoneminder HTTP/HTTPS web interface auth
# Logs auth failures to apache2 error log
port    = http,https
[traefik-auth]
# to use 'traefik-auth' filter you have to configure your Traefik instance,
# see `filter.d/traefik-auth.conf` for details and service example.
port    = http,https
logpath = /var/log/traefik/access.log
[scanlogd]
logpath = %(syslog_local0)s
v-list-sys-config json | grep FTP | sed -E ‘s/^\s*//’
"FTP_SYSTEM": "",
Thank you so much for your time! :slight_smile:
Are you sure you are showing jail.local? Because that output looks like jail.conf
Execute this command and check if you see vsftpd in Hestia:
v-change-sys-config-value FTP_SYSTEM 'vsftpd'
Yes, I can try again:
# [DEFAULT]
# bantime = 1h
# [sshd]
# enabled = true
[INCLUDES]
[DEFAULT]
#bantime.rndtime =
#bantime.maxtime =
#bantime.factor = 1
#ignoreself = true
ignorecommand =
bantime  = 10m
# seconds.
findtime  = 10m
maxretry = 5
backend = auto
usedns = warn
logencoding = auto
enabled = true
mode = normal
# ACTIONS
mta = sendmail
# Default protocol
protocol = tcp
port = 0:65535
# to the destemail.
# to the destemail.
# to the destemail.
# JAILS
# SSH servers
[sshd]
#mode   = normal
port    = ssh
[dropbear]
port     = ssh
[selinux-ssh]
port     = ssh
# HTTP servers
[apache-auth]
port     = http,https
[apache-badbots]
port     = http,https
bantime  = 48h
maxretry = 1
[apache-noscript]
port     = http,https
[apache-overflows]
port     = http,https
maxretry = 2
[apache-nohome]
port     = http,https
maxretry = 2
[apache-botsearch]
port     = http,https
maxretry = 2
port     = http,https
maxretry = 1
port     = http,https
maxretry = 2
[apache-shellshock]
port    = http,https
maxretry = 1
[openhab-auth]
filter = openhab
[nginx-http-auth]
port    = http,https
[nginx-limit-req]
port    = http,https
[nginx-botsearch]
port     = http,https
maxretry = 2
[php-url-fopen]
port    = http,https
[suhosin]
port    = http,https
[lighttpd-auth]
port    = http,https
[roundcube-auth]
port     = http,https
[openwebmail]
port     = http,https
[horde]
port     = http,https
[groupoffice]
port     = http,https
[sogo-auth]
# port    = 20000
port     = http,https
[tine20]
port     = http,https
# Web Applications
[drupal-auth]
port     = http,https
[guacamole]
port     = http,https
[monit]
port = 2812
           /var/log/monit.log
[webmin-auth]
port    = 10000
[froxlor-auth]
port    = http,https
[squid]
[3proxy]
port    = 3128
# FTP servers
[proftpd]
[pure-ftpd]
[gssftpd]
[wuftpd]
[vsftpd]
# Mail servers
[assp]
[courier-smtp]
[postfix]
mode    = more
[postfix-rbl]
maxretry = 1
[sendmail-auth]
[sendmail-reject]
#mode    = normal
[qmail-rbl]
filter  = qmail
[dovecot]
[sieve]
[solid-pop3d]
port    = pop3,pop3s
[exim]
#mode = normal
[exim-spam]
[kerio]
[courier-auth]
[postfix-sasl]
[perdition]
[squirrelmail]
[cyrus-imap]
port   = imap,imaps
[uwimap-auth]
port   = imap,imaps
# DNS servers
# !!! WARNING !!!
#   victim. See
# port     = domain,953
# protocol = udp
[named-refused]
port     = domain,953
[nsd]
port     = 53
# Miscellaneous
[asterisk]
port     = 5060,5061
maxretry = 10
[freeswitch]
port     = 5060,5061
maxretry = 10
[znc-adminlog]
port     = 6667
# log-warnings = 2
# [mysqld_safe]
# syslog
# for own logfile
# [mysqld]
[mysqld-auth]
port     = 3306
[mongodb-auth]
port     = 27017
# !!! WARNINGS !!!
[recidive]
bantime  = 1w
findtime = 1d
[pam-generic]
[xinetd-fail]
maxretry  = 2
[stunnel]
[ejabberd-auth]
port    = 5222
[counter-strike]
[softethervpn]
port     = 500,4500
protocol = udp
[gitlab]
port    = http,https
[grafana]
port    = http,https
[bitwarden]
port    = http,https
[centreon]
port    = http,https
[nagios]
maxretry = 1
[oracleims]
[directadmin]
port = 2222
[portsentry]
maxretry = 1
[pass2allow-ftp]
blocktype    = RETURN
returntype   = DROP
bantime      = 1h
maxretry     = 1
findtime     = 1
[murmur]
# AKA mumble-server
port     = 64738
[screensharingd]
logencoding = utf-8
[haproxy-http-auth]
[slapd]
port    = ldap,ldaps
[domino-smtp]
port    = smtp,ssmtp
[phpmyadmin-syslog]
port    = http,https
[zoneminder]
port    = http,https
[traefik-auth]
port    = http,https
[scanlogd]
v-change-sys-config-value FTP_SYSTEM ‘vsftpd’ → This command returns nothing
Where is the right jail.local conf? Did you do something?
ls -la /etc/fail2ban/
It shouldn’t return anything, now check whether you see vsftpd service in Hestia… or run this command:
 v-list-sys-services
or
 v-list-sys-services | grep vsftpd
total 108
drwxr-xr-x   6 root root  4096 juin   7 19:50 .
drwxr-xr-x 125 root root 12288 juin   7 20:00 ..
drwxr-xr-x   2 root root  4096 sept. 16  2023 action.d
-rw-r--r--   1 root root  2816 nov.  23  2020 fail2ban.conf
drwxr-xr-x   2 root root  4096 mars  10  2022 fail2ban.d
drwxr-xr-x   3 root root  4096 sept. 16  2023 filter.d
-rw-r--r--   1 root root 25071 mars  10  2022 jail.conf
drwxr-xr-x   2 root root  4096 sept. 16  2023 jail.d
-rw-r--r--   1 root root 27153 juin   7 19:50 jail.local
-rw-r--r--   1 root root   645 nov.  23  2020 paths-arch.conf
-rw-r--r--   1 root root  2827 nov.  23  2020 paths-common.conf
-rw-r--r--   1 root root   650 mars  10  2022 paths-debian.conf
-rw-r--r--   1 root root   738 nov.  23  2020 paths-opensuse.conf
I’m not very technical but it seems to really be that file, otherwise I didn’t do anything, no haha
v-list-sys-services
NAME        STATE    CPU   MEM  UPTIME
nginx       running  0.2   214  75
php8.3-fpm  running  45.6  101  75
exim4       running  0     67   72
dovecot     running  0     0    72
mariadb     running  2.7   584  72
vsftpd      running  0     1    72
cron        running  0     0    72
ssh         running  0     3    72
iptables    running  0     0    0
fail2ban    stopped  0     0    0
Ok, Hestia now can see vsftpd service.
To solve the jail.local issue.
cp /usr/local/hestia/install/deb/fail2ban/jail.local /etc/fail2ban/jail.local
systemctl restart fail2ban
Woaw!!! Thank youuu so much it works!!!
You are welcome :wink:
Just for the records, the script you executed didn’t cause the problem, you had the problem before executing the script :stuck_out_tongue:
Also, if you want to enable fail2ban for vsftp you should edit the file /etc/fail2ban/jail.local and modify enable = false to true for vsfptd-iptables
Before:
[vsftpd-iptables]
enabled  = false
filter   = vsftpd
action   = hestia[name=FTP]
logpath  = /var/log/vsftpd.log
maxretry = 5
After:
[vsftpd-iptables]
enabled  = true
filter   = vsftpd
maxretry = 5
Save the file and restart again fail2ban.
Ohhhh, okayy, I’m happy at least I’ve been able to see it thanks to the script hahaha
Thanks I did it :smiley:
