Hello Marcus,
Let me go through your misunderstanding one by one:
Nowhere in my message I have mentioned that the concept of subdomain.DynDNS will protect the entire server and all the ports. The list and methods of hacking a system, which you describe above, is then not relevant because the solution triggers only on ONE SPECIFIC PORT BOUND TO ONE SPECIFIC IP ADDRESS!
The concept of subdomain.DynDNS has nothing to do with DynDNS.com. The abbreviation simply means that it is a dynamic ip address. Because you assumed that it correlates to services offered by a company, you mention about the CNAME. CNAME has nothing to do with the idea of binding a port with an ip address.
If I configure - with my concept - each port opened by any service, for e.g. 80, 443, 993, 995, 3306, etc. and bind these services to one dynamic ip address (subdomain.DynDNS), then a possibility to hack that service becomes null, unless the kernel is hacked. For a hacker with a different ip address, the kernel declares that secured port to be closed.
In fact, I use dovecot, sshd, webmin, hestia, vsftp, etc. EXCLUSIVELY on specific ports opened to allow traffic to the router ip address (subdomain.DynDNS) that changes dynamically as well as the cluster servers. I myself can access my emails from my router ip address only. Outside, I can access using roundcube under a specific subdomain protected with .htaccess.
I rejected use of services offered by companies based under the jurisdiction of Patriot Act. I use provider within the European Union for binding services to that subdomain.DynDNS. Only necessary ports remain open for public.
Hestia has taken a lot of distance from VestaCP and has dramatically enriched security in it.
However, why should a sensitive port should remain accessible and open to 0.0.0.0/24 by default, when this port could be bound to 123.456.123.456 (router dynamic ip address)? Due to binding ports to a specific ip address, there are advantages. Thereafter, ironing vulnerabilities besomes a small issue.
Not binding it and making it remain open to public invites hackers to theaten that port.
