File Manager Problem
Hello there,
Recently I have started using Hestia Control Panel, and I got one problem. Inside of File Manager there is a problem when I try to zip a files. Also I want to know how can I download those files to my PC after I zip them. Can by some way a Hestia provide me a link which will be destroyed after 72 hours like it is on Pterodactyl or?
Thanks in advance
Specific needs need to be customized, File Manager is only suitable for hestia management side,
is a file program station, it can compress files online, and generate a file package, you can ask the developer to help you update a version separately, so that the archive can be automatically deleted after how many hours. It’s a great file manager!
But can I download that .zip file from File Manager, is there a button like Download?
Of course, you can add a domain name to test and deploy it and try it out
This is the file and style structure given by the developer
小文件管理器 |H3K |演示
Is it better to try installing FTP instead of doing all of this? Btw here is my domain hqris.rip:2083
No, this is not a domain name, this is the admin web side of Hestia. You can add an alias domain name to it.
For example: fm.hqris.rip,
In fm.hqris.rip, it is very easy to add management files to the website, and you can also use hqris.rip for file management.
FTP does not have this utility if you are using file management,
Port 2083 belongs to your server’s management page. The public cannot access your files without a password; it is solely under your management. No one else can view it, and you need to deploy a separate webpage for it. Do you understand?
In addition, FTP is relatively troublesome to operate, and web management is more convenient.
You can download translation.json and translation.php to your hqris.rip domain .
translation.php rename to index.php, remove index.html. Refresh the page to see the results, the hqris.rip domain management file is located in your server’s home/admin/web/hqris.rip/public_html
I don’t see the issue:
I need something where only I can access the files thats why I thought about FTP where I can use WinSCP on my PC and connect to the server. I only need it to be able to zip file and download it do my PC. And I need a shortest way to do that and easiest.
You can directly use the FTP tool to connect to your cloud service, and the port uses 22 account and password, you can add it to Hestia or use the cloud service account and password!
