Hello, here’s the problem, not sure if after updating Hestia, but Hestia updated about 5 versions above.
When I visit one of the domains, I get an error “File not found.”, but not the standard page from Hestia, but the most ordinary text is written.
At the same time I can not open the php file, such as phpinfo.
Also, for some reason does not determine the index.html, I have to go directly to domain.com/index.html
On other domains, php seems to work, but for example the backend in octobercms (it is written in php and based on laravel framework) works badly, the backend home page loads endlessly, but some of the tabs open, very strange
From what I changed, only in the configuration /etc/apache2/conf.d/phpmyadmin.inc
and /etc/nginx/conf.d/phpmyadmin.inc
added "Require expr %{HTTP_HOST} == "my_domain" and "if ($http_host != "my_domain") {return 403; }"
Accordingly, to make the panel work only on a certain domain
Please help me, where do I start?
UPD:
When I created a new domain or used “v-rebuild-web-domain”, it has now broken and writes me “ERR_TOO_MANY_REDIRECTS”
