Filegator doesn’t overwrite files with the same name. So updating files is unnessecary complicated. I tried the following, but it didn’t work.
Filegator has the config option since Version 7.3.4
According to changelog Hestia uses 7.13.0 - so it should work.
I did the following:
nano /usr/local/hestia/web/fm/configuration.php
and added
$dist_config["overwrite_files_on_upload"] = true;
just before the end (return $dist_config;)
I also restarted Hestia and php
systemctl restart hestia
It didn’t change anything. Did I something wrong? If yes, how is it done properly to get files overwritten if a file with the same name is uploaded?
Best, Michael
