Fix for Safari/iOS error NSPOSIXErrorDomain:100
Hello everyone,
I have been running HestiaCP v1.3.2 on Debian 10.6 and nginx is configured in front of apache as a reverse proxy.
Unfortunately, using Safari browser on Mac or iOS devices to access https sites, doesn’t open sites hosted on HestiaCP and displays an error NSPOSIXErrorDomain:100.
This problem is described in many other sites and control panels, e.g. https://trac.nginx.org/nginx/ticket/2078 and the fix they recommend works (proxy_hide_header Upgrade).
Here is a quick script I hacked to enable this in all sites hosted on my Hestia installation.
root@potato:~# cat bin/v-fix-web-domains
#!/bin/bash
# deploy fix for safari browser problem accessing https sites
USERS="$(v-list-users plain | awk '{print $1}')"
for u in ${USERS}; do
        DOMAINS="$(v-list-web-domains ${u} plain | awk '{print $1}')"
        for d in ${DOMAINS}; do
                source /usr/local/hestia/data/users/${u}/web.conf
                if [ "$SSL" == "yes" ]; then
                        echo "proxy_hide_header Upgrade;" > /home/${u}/conf/web/${d}/nginx.ssl.conf_safarifix
                fi
        done
done
nginx -t && systemctl reload nginx
Is there a hook I could use to deploy automatically this nginx snippet when I add a new web domain instead of having to manually run this hacky script every time I add something ?
Thanks,
Sot.
I have seen the issues mainly when “creating” a video player and wasn’t able to pin point the cause…
I think it might be worth adding it in the templates by default.
If possible please create an pull request via:
You will need to modify the following templates:
Thank you very much @eris!
Here is a pull request for the templates you mentioned
Plz remove proxy_hide_header Upgrade by default, this is wast my time about 8 hours, like him:
So it breaking a ton of OSX/IOS users or waisting 2 users time who are use websockets?
I pick the last option
