Today (2024-06-14), Nginx signing key expired so if you try to apt update, you will see an error similar to this:
Err:8 https://nginx.org/packages/mainline/debian bookworm InRelease
The following signatures were invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key <[email protected] >
To solve it:
sudo su -
curl -s https://nginx.org/keys/nginx_signing.key | gpg --dearmor > /usr/share/keyrings/nginx-keyring.gpg
or
curl -s https://nginx.org/keys/nginx_signing.key | sudo gpg --dearmor > /usr/share/keyrings/nginx-keyring.gpg
dyrer
June 16, 2024, 2:32pm
3
something like that for ubuntu??
It works for me! Thanks @sahsanu
That did not work for me.
Here is what I ended up doing on all three servers:
apt-key del 7BD9BF62
apt-key del B49F6B46
apt-key del 8D88A2B3
apt-key adv --fetch-keys https://nginx.org/keys/nginx_signing.key
gpg --dry-run --quiet --no-keyring --import --import-options import-show /usr/share/keyrings/nginx-keyring.gpg
Seems you are not using the right nginx.list.
Could you please show the output of this command?
cat /etc/apt/sources.list.d/nginx.list
deb [arch=amd64 signed-by=/usr/share/keyrings/nginx-keyring.gpg] https://nginx.org/packages/mainline/debian/ bullseye nginx
That is the right one so I don’t understand the reason it didn’t work in your server.
I’ve managed to fix it on my Ubuntu Focal machine by repeating the steps on nginx: Linux packages
This worked for me (Ubuntu 22.04 Server)
sudo su -
migmae
June 24, 2024, 3:05pm
18
If not working, try
curl -O https://nginx.org/keys/nginx_signing.key && apt-key add ./nginx_signing.key
Source: Updating the GPG Key for NGINX Products
ronald
June 30, 2024, 8:24pm
19
Also worked for me (Ubuntu 20.04 Server)
sudo su -
ToNov
July 12, 2024, 4:00pm
21
None of those works for me on Ubuntu 22.04. So I just followed the steps on Updating the PGP Key for NGINX Software – NGINX Community Blog
And this worked for me →
curl https://nginx.org/keys/nginx_signing.key | gpg --dearmor | sudo tee /usr/share/keyrings/nginx-archive-keyring.gpg >/dev/null
After that →
apt-get update
Not worked on my Ubuntu 22.04.4 LTS
gpd: no valid OpenPGP data found
